04-07-2016, 09:52 AM | #1 |
Newbie Join Date: Mar 2016 Location: Royal Oak
| Motor Shaft Short? |
04-07-2016, 11:06 AM | #2 |
Quarry Creeper Join Date: Jan 2013 Location: Athens
| Re: Motor Shaft Short?
Check your instruction manual, that assembled wrong. See image 21 http://docs.axialracing.com/instruct...%84%A2_KIT.pdf |
04-07-2016, 11:13 AM | #3 |
Quarry Creeper Join Date: Mar 2016 Location: Moses Lake
i think he as the wraith spawn, the slipper clutch is different on the spawn then the regular wraith. i think i flipped my pinion around think it fit better that way try that and see if that works for ya.
04-07-2016, 11:48 AM | #4 |
Its fine, not a problem.
04-07-2016, 11:51 AM | #5 |
| Re: Motor Shaft Short? |
04-07-2016, 11:55 AM | #6 |
Yep, fine. And if he flips the pinion what do you think the set screw will grab? Air? |
04-07-2016, 12:41 PM | #7 |
Ya, it's a Spawn kit. Has that aluminum spur gear spacer. Everything seems to be assembled according to the manual. If the slipper driveshaft were set back any further it'd poke out the back of the trans case. I'll go with what Mr. Holmes said. Thanks.
Motor Shaft Short? - Similar Threads | ||||
BWD MRC Motor Spacer - for short shaft motors | billet works | Losi Mini-Rock Crawler | 0 | 08-20-2010 09:32 AM |
Shaft too short. Help! | AKcrall | HPI Wheely King | 0 | 07-26-2010 11:22 PM |
Short shaft | sullysracin | Newbie General | 1 | 01-15-2010 06:09 AM |
