04-07-2016, 05:40 PM | #1 |
Quarry Creeper Join Date: Feb 2014 Location: NNJ in the sticks
| Forward battery mod DIY or buy?
So the wraith RTR is apart awaiting a WP Holmes combo. I want to mount the battery forward but can't decide if I should buy a plate or fab something up. I'm looking to the experience of others that have done it as how to proceed. If I'm going to fab something the existing battery box mounted and chopped for top load seems the way to go. I'd like to keep the existing radio box close to stock position so I can mount my castle BEC inside to avoid having to waterproof it. I have conformal coating to do it but reading the label it seems to be toxic to everything that walks the earth. I haven't decided where the ESC will go and I'm concerned with wire length. Not sure if I can extend the BEC power wires but since they are small gauge I don't think extending them a bit will cause resistance issues. Maybe park the ESC in the stock battery position and extend as needed. I have a bunch of .012 aluminum to make mounting plates. The 5000 mah batteries I run makes me have to mount the radio box more to the nose. I am concerned with clearance issues with the steering servo. Will removing the front screw mount and moving the box .25-.375" forward work? I'm thinking of removing the rear box standoffs as well and just mounting it to a plate with servo tape. How much clearance from the servo (HS-7955TG) to the stock box placement is there? If anyone could give me a ballpark measurement it would save me from putting everything back together to see. If buying a mount is the best option what one should I go with? |
04-07-2016, 05:48 PM | #2 |
Quarry Creeper Join Date: Feb 2015 Location: Norway
| Re: Forward battery mod DIY or buy?
I went with this one, cheap and excellent quality. Wertymade Wraith forward mount battery tray Stub Nose w/Servo winch mount |
04-07-2016, 05:51 PM | #3 |
Rock Crawler Join Date: Jan 2008 Location: P-TOWN
I just used the stock rear tray and modded it to the front under the hood. I looked but could not find a link. Do a search, its somewhere on here. Here is my Mod |
04-07-2016, 09:41 PM | #4 |
RCC Addict Join Date: Apr 2009 Location: LA
| Re: Forward battery mod DIY or buy? |
04-07-2016, 10:55 PM | #5 |
Lol. Ya I know. Only pic I had. But you get the idea. Here is a thread I found. The mod involves cutting up the rear stock tray, mounting it up front there under the hood. Best part.....it's a free mod front battery position in Wraith |
04-08-2016, 12:22 AM | #6 |
Nice; thanks for the link! |
04-08-2016, 08:26 AM | #7 |
Nice, that's pretty much what I was thinking. I am thinking of trimming a little less off the stock box but it will depend on how hard it is to get the battery in. I've already made a template for a plate up front to mount the radio box. I am still wondering about the clearance on the servo.
04-08-2016, 01:18 PM | #8 |
Newbie Join Date: Mar 2015 Location: Chino valley
A gens ace 5000mah fits perfect without a mod! Just take out the cross brace in the way Sent from my SM-N910V using Tapatalk |
04-08-2016, 01:26 PM | #9 |
Quarry Creeper Join Date: Apr 2015 Location: Georgia
I was also wondering what most people do about mounting the battery up front
04-08-2016, 03:51 PM | #10 |
I'm in the process of making up templates for a new radio tray and possibly body panels tonight. The metal I have here is too thin to create a battery tray so chopping the stock mount is on the list. If the beer doesn't interfere I'll try and post some pictures later. I'm trying to avoid removing the crossbrace as it probably adds a good bit of torsional rigidity to the chassis. I know in road racing a nice stiff chassis helps a lot. I'd expect the same to hold true on the rocks. |
04-08-2016, 07:40 PM | #11 |
Quarry Creeper Join Date: May 2007 Location: Montucky
I laid the battery tray horizontal vs vertical. Drilled some holes added some velcro and use the cross bar as an extra hold down.
04-08-2016, 09:08 PM | #12 |
Rock Crawler Join Date: Mar 2016 Location: Murphy
Found a template at Harley Designs for a front battery tray. I took Harley's design and modified it a bit as I wanted ends in the tray. Part of the center console sticks into the area where there tray goes. I trimmed it at the floor and just folded them back so I could slide the tray into place. I painted mine with Duplicolor Truck Bed Liner |
04-08-2016, 09:45 PM | #13 |
Newbie Join Date: Mar 2016 Location: SAN DIEGO
Here's mine. I can fit the hard pack in mine if I run one connector up and one down. Pic explains it better. The palate I got from a buddy of mine. |
04-12-2016, 09:09 PM | #14 |
RCC Addict Join Date: Jul 2008 Location: San Diego
Post #4 Move the battery lower and back. SDheavymetal's Wraith I installed a Locked Up RC slipper eliminator to get more room for the battery. |
04-24-2016, 07:48 AM | #15 |
Newbie Join Date: Apr 2016 Location: Gainesville
04-24-2016, 08:59 AM | #16 |
Hobby people 2s 5000mah hard pack Sent from my SM-G930P using Tapatalk |
Forward battery mod DIY or buy? - Similar Threads | ||||
battery size for forward mod | 123nanez | Axial Wraith | 5 | 01-22-2015 05:19 AM |
Help with DIY 4 link mod | DinehCaveman | Losi Mini-Rock Crawler | 0 | 06-12-2014 12:20 AM |
Just finished battery forward mod. | KBR97 | Axial Wraith | 4 | 04-11-2014 05:07 PM |
