04-11-2016, 12:57 PM | #1 |
Rock Stacker Join Date: Oct 2015 Location: Kingston, WA
| Rock Beast XOR tires
Does anyone run these tires? What do you think of them and which foams did you run in them as well? Thanks in advance. |
04-11-2016, 02:31 PM | #2 |
Rock Crawler Join Date: Nov 2013 Location: In the country
| Re: Rock Beast XOR tires
good question, I have set and I'm hearing they fit gear head wheels 1 1/2 wide best. They are a fat tire from what I can tell, but super soft!. I have an old set of methods and I'm going to try and use CI Deuces wild talls with a outer foam from pit bull foams to take up more space. Seems pretty decent but probably not optimal. I'm just trailing with em.
04-11-2016, 11:50 PM | #3 |
I run XORs and they're a fantastic crawler tire. Amazing grip on rock. Everywhere else they feel pretty comparable to rock beasts but XORs really shine in the rocks. I run CI double deuces comp cut inners with medium outers all around and yes, they are a wide tire. I would say the minimum rim width you should be looking at mounting these on is 1.5 inches wide. I have mine mounted to Axial plastic methods and they fit and look awesome.
04-12-2016, 11:07 AM | #4 |
Thought I should add a pic. When you first pull these out of the package they look ridiculous, very short and wide. Once you get the foams in them they start to stand up and take shape better and once mounted look really good. No other tire I've mounted changes shape as drastically as these do from unmounted to mounted.
04-12-2016, 11:12 AM | #5 |
I wanna be Dave Join Date: Sep 2012 Location: Victoria, BC
| Re: Rock Beast XOR tires |
