Thread: Proline shock spring rates
Old 04-11-2016, 04:41 PM   #1
Default Proline shock spring rates
I just received a set of proline powerstroke shocks for my wraith. I'm very impressed with the fit & finish but, the as shipped spring rate seems pretty stiff.
What spring set up would be a good starting point for a built up Wraith?
I have plenty of different oils to work with but, I'll have to pick up some new springs.
Thanks
CG3 BadAssRC
chipgibbs is offline   Reply With Quote
Old 04-11-2016, 06:56 PM   #2
Default Re: Proline shock spring rates
Personally on my Wraith for crawling I run the Axial "purple" 1.43lb/" springs on Traxxas Big Bore shocks.
Now they're only a 14mm spring so I don't think they'll fit the PL shocks (17mm I think) but I think you'd be looking for that 1.4-1.5lb range, unless your Wraith is particularly heavy.
http://www.prolineracing.com/images/...SpringRate.pdf
altd896 is offline   Reply With Quote
Old 04-12-2016, 08:21 PM   #3
I run the proline yellow mediums on gmade xd's. I've only tested in my yard but they seem good. My wraith is heavy. I would try the softs up front and maybe super softs in the rear with 30-35 wt oil. If you've moved your battery up front I'd go with softs in front and rear. Good thing is each spring set comes with choices so you can dial in your springs
cyberhog05 is offline   Reply With Quote
Old 04-13-2016, 05:29 PM   #4
I've ordered a couple of spring sets from proline. Thanks for the input.
CG3.
Proline shock spring rates - Similar Threads
Leaf spring kits and spring rates BansheeManiac Axial SCX-10 2 09-22-2010 02:23 PM
spring rates & shock lenghts 73fordhighboy Duratrax Cliff Climber 1 09-30-2009 02:12 PM
losi shock spring rates limpy88 General Crawlers 3 08-07-2009 07:02 AM
savage shock spring rates? muddeprived General Crawlers 2 05-05-2007 11:44 AM
shock: oil and spring rates???? rockhound General Crawlers 0 03-04-2005 12:06 PM
