04-14-2016, 04:41 AM | #1 |
Quarry Creeper Join Date: Jun 2013 Location: Australia
| Leading arms for Wraith
Anyone running leading arms on their Wraith? I'm currently running Yeti trailing arms on my wraith (set up for U4) and am thinking about using leading arms as well. Not sure if anyone has yeti arms front and back? Or if twin hammers arms might be better for the front leading arms on a wraith? Anyone? Thanks Sent from my iPhone using Tapatalk |
04-14-2016, 08:45 AM | #2 |
Rock Crawler Join Date: Mar 2015 Location: "Crawling Heaven"
| Re: Leading arms for Wraith
What's are "leading" arms exactly? __________________________ 1.9 Ibex tuber - The Merica ibex. |
04-14-2016, 09:04 AM | #3 |
Quarry Creeper Join Date: Dec 2015 Location: United States
| Re: Leading arms for Wraith |
04-14-2016, 09:06 AM | #4 |
Ahhh. I'm pretty sure Twin hammers will work. Not sure exactly. __________________________ 1.9 Ibex tuber - The Merica ibex. |
04-14-2016, 11:06 AM | #5 |
Rock Crawler Join Date: Nov 2013 Location: In the country
I run stainless trailing arms in back and stainless leading arms up front (j.e.c racing). Adds LCG to the wraith and brutal strength.
04-14-2016, 11:18 AM | #6 |
04-14-2016, 01:08 PM | #7 |
04-14-2016, 02:08 PM | #8 |
04-14-2016, 03:40 PM | #9 | |
| Re: Leading arms for Wraith Quote:
If you like the trailing and/or leading arms, great, bolt them up and enjoy. | |
04-14-2016, 05:00 PM | #10 | |
RCC Addict Join Date: Aug 2013 Location: Missoula
04-14-2016, 06:11 PM | #11 |
Baja, desert, trophy, stadium, are different trucks dip-****, traveling and cornering at high speeds and leaving, then returning to the ground at those high speeds warrants a different suspension. Trailing arms have their place in off-road racing, but they're not at all necessary on a Wraith or any rock-racer/bouncer/crawler. But people like the way they look, and some feel they have to justify why they made the switch. I guess "because I wanted to" just isn't reason enough for them.
04-14-2016, 06:57 PM | #12 | |
Haha when anger and uneducated mixes you get this guy. Give it a rest mate. We get it - you think trailing arms are just for looks. Fortunately your anger makes you easily dismissed. As original post says, this set up is for Ultra 4 and thus high speed travelling and cornering etc is exactly what the suspension is required to do. Thanks to those who contributed in a helpful way. I am going to give the TH arms a miss as they are a touch short and then don't have rod ends that allow lengthening and shortening like the Blue Monkey ones do. | |
04-14-2016, 09:18 PM | #13 | |
I know some of you guys get your feelings hurt and defensive when someone "dis's" your beloved trailing arms. So it will be hard for you to understand this, but there's nothing anyone could say or do on a forum to actually make me the slightest bit angry. I'm not that fragile or temperamental. I quit getting angry with anonymous internet travelers a long time ago. If I start getting annoyed with someone or they become tedious, I just quit reading their posts long before their mild nuisance could induce anger. As for uneducated, you're the one buying the trailing arm hype. Yes, unlike you, I did think. Then I researched, actual research, not forum gossip. Then I worked and experimented with both. Trailing arms on the front or rear of a Wraith are purely aesthetic. You can get the same lift, drop, articulation, "twist", "rotation", stability, durability, etc., etc. from the links. Trailing arms are simply not necessary on this particular vehicle. However, aside from adding a little bulk when compared to the links, they're not hindering anything either. So, if you like the way they look, run them until the next "innovation" appears. | |
04-14-2016, 09:33 PM | #14 | |
I run them because of the performance improvement which they yield. I am not worried about how they look underneath my wraith. We don't tend to go around admiring other driver's bottom sides very often but hey, if that's your thing... Sent from my iPad using Tapatalk | |
04-14-2016, 10:49 PM | #15 |
Pebble Pounder Join Date: Dec 2013 Location: central
Trailing vs leading arms are typically determined by packaging. The front frame of most race rigs have sufficient strength to mount the shocks forward enough to attach them to the axle. They also typically don't have as much travel as the rear, especially trophy trucks. The rear typically uses trailing arms so the upper shock mounts can be incorporated into a high strength frame area, they also tend to run extreme amounts of travel, where having the shock attached further up the arm gives it the length to allow such travel. Imagine how big the shock would be to have a 36"-40" stroke.
04-15-2016, 08:57 AM | #16 |
My Wraith goes 25. Well it used to, until it was parted out to build a Bomber. The longer trailing arm suspension is a massive improvement over the Wraith. A WE Rock jeep and a KOH jeep are both jeeps. Serve different purposes though. And I wouldn't be too happy about anyone I know calling me a dipshit. I am an adult and don't "pick on" people like a child. |
04-15-2016, 01:31 PM | #17 | |
RCC Addict Join Date: May 2009 Location: Weston
I would go witht he Wraith length just to keep the wheelbase down a bit. It's going to start getting pretty long with Yetis front and rear. | |
04-15-2016, 03:25 PM | #18 |
Rock Crawler Join Date: May 2007 Location: Corona, CA
| Re: Leading arms for Wraith I can guarantee you are wrong sir. To the OP, yes leading arms are a great set-up for U4rc and I can say for sure I have noticed my rig has worked much better ever since I have gone that route. For U4rc you can actually run Yeti trailing arms front and rear and that would still let you be legal at the 15in wheel base. Last edited by Shoei1; 04-15-2016 at 04:09 PM. |
04-15-2016, 05:23 PM | #19 |
| Re: Leading arms for Wraith That's why I wasn't talking to him in the first place, he was already a trailing arm "drinker". Since we're on the subject anyway, I didn't ask for your opinion, hype or bull-shit either. It was a differing view point voiced to another person, get over it and move on.
04-15-2016, 06:31 PM | #20 | |
Leading arms for Wraith - Similar Threads | ||||
Trailing & Leading arms for Wraith | byrnieman | Axial Wraith | 2 | 01-18-2016 03:01 PM |
Wraith Trailing Arms? | mudbeast2 | Axial Wraith | 28 | 01-09-2016 09:18 AM |
VP ackerman arms for wraith on a TH??? | stick-boy-rick | Vaterra Twin Hammers | 1 | 03-11-2013 08:38 PM |
