Thread: New SSD 2 Speed Transmission kit for Wraith
Old 12-19-2016, 10:13 AM   #41
SSD
Default Re: New SSD 2 Speed Transmission kit for Wraith
There are no "hard plastic" parts, it's a machined aluminum connector that threads onto the steel shift rod. Put some threadlock on the thread or as you said, a nut is also fine if it fits.
It will only kick out of gear if your servo is not holding it. So either your servo/receiver is not working as it should or your end points are not in the correct place to put it into gear fully. I recommend using a high torque servo saver also.
SSD is offline   Reply With Quote
Old 12-20-2016, 11:16 AM   #42
Thanks! Happy to hear that component is aluminum. If the nut fails I'll use thread locker as suggested. I put a Savox 0230 111 oz. servo and Kimborough servo saver. Now the SSD 2 speed is hooked to a 4600KV 1406 Castle Sensorless; top speed, high gear the shift rod doesn't move a nano-meter! Great fun. Money well spent. When looking for new parts I definitely will be looking at SSD first.
Rybroca is offline   Reply With Quote
Old 12-27-2016, 05:10 PM   #43
Moderator
JatoTheRipper's Avatar
Will this drop in an original SCX10?
Old 12-28-2016, 04:06 PM   #44
SSD
Yes, but I think you need to flip the trans mount/skid the other way and a shorter rear driveshaft.
New SSD 2 Speed Transmission kit for Wraith - Similar Threads
The New SSD-RC High Ratio Wraith Transmission Kit KRAWLR4life Axial Wraith 18 08-22-2016 05:14 AM
RTR Yeti: Servo and radio options for SSD 2 speed kit? KellyC Axial Yeti 10 06-22-2015 07:14 PM
