04-21-2016, 09:37 PM | #1 |
Newbie Join Date: Apr 2016 Location: Deer Park
| Axial Wraith Questions & Help
Hello guys! This is all new to me and my 11 year old daughter that's found us a new hobby. I recently bought a new Axial Wraith for us to rock crawl with. The city where I live just built a new rock park and we have had so much fun playing together. Problem is, we are already breaking things. My rig is pretty much stock other than the new Savox SC-1268 servo I put on it tonight. The old stock servo broke so instead of us not getting to hang out tonight I took her to our local hobby shop and bought this new servo. Question is, how good is it really? Should it be this loud, meaning it's always making noises not just when I turn. I do not have a BEC on it, but I'm not having any trouble with it diming or "brown out" like I think you guys call it. I am running a 7.4V 5000mAh 25c Lipo. My plan is to eventually as things break replacing everything on it to turn it into one crazy Rock crawler. Any ideas what might break next that I should worry most about or what I should buy next that would improve our rig the most? |
04-21-2016, 10:37 PM | #2 |
| Re: Axial Wraith Questions & Help
Plenty of threads exactly like this one that ask what first mods are needed to have a reliable truck. Check the Harley threads at the top of this page for more info than you'll be able to process in one night. Welcome to the forum.
04-21-2016, 10:59 PM | #3 |
Rock Stacker Join Date: May 2015 Location: Reno
x2 on the "chattering" of the servo. Ive always figure it was a normal thing but I know the castle BEC doesn't come out of the box tuned to the power my servo recommends.
04-21-2016, 11:05 PM | #4 |
Pebble Pounder Join Date: Mar 2016 Location: GC
I have a Tactic tsx45 that does the same thing. But I have 2nd tsx45 that doesn't constantly make noise. But both work fine?
04-22-2016, 06:19 AM | #5 |
Rock Stacker Join Date: Aug 2011 Location: 30 min west of ATL
To answer the op, yes savox servos are noisy. I run one in my wraith. The next thing I would look into purchasing is a motor. Those 20t axial motors don't last long. I don't mean spend a fortune, just get a 40$ 35t motor from Holmes hobbies.
04-22-2016, 06:20 AM | #6 |
04-22-2016, 06:36 AM | #7 |
Quarry Creeper Join Date: Jun 2015 Location: Athol, Massachusetts
To get the most from that servo get a bec and set it to 7.4. The internal bec probably wont last long and not a good reason to brake down on a nice day.
04-22-2016, 10:07 AM | #8 |
RCC Addict Join Date: Jul 2008 Location: San Diego
I would recommend a Castle BEC. I'm a big fan of Hitec servo's!
04-22-2016, 11:43 AM | #9 | |
Newbie Join Date: Sep 2010 Location: Canada
| Re: Axial Wraith Questions & Help Quote:
As far as the Savox servo goes they are quite noisy. I have 3 now and I just learned to live with it. Other than noise I have no complaints. But definitely get yourself a BEC to get the power to your servo. The one thing that irritated me the most about the stock wriath was the flimsy steering links. I do unederstand that they were designed as such to work like a "servo saver" but after a few runs it was time for them to go. I also wasn't a fan of the stock front axles and how they had the "wobble" in them when you have your tires turned all they way. So I changed those out right away and also got a little more steering out of it by going to Vanquish VVD's. There are quite a few other companies that have upgrades in that departement as well | |
04-22-2016, 11:49 PM | #10 |
Quarry Creeper Join Date: May 2007 Location: Montucky
Until you go with more power I would focus my attention on all things plastic. Steering, suspension links, c hubs, knuckles, shocks. Then look at motor, esc , metal trans gears, mips and vvds to get that power to the axles. It adds up quick but the end result is fun, and it's hard to put a price on that specially since your daughter is playing to. A second rig is in your future as you dive further into this hobby |
04-23-2016, 02:51 PM | #11 |
I don't think my Savox 1230 is any noisier then any other high output/torque digital servo that I've used. Most all digital servos will make some noise as they continually make attempt at hunting for center/neutral. This causes a bacon sizzling sound while it attempts to find center. But should cease if your steering servo/linkage finds it's neutral point and the tires are not bound inbetween rocks and such. If something is restricting the servo's ability to find center (neutral)... the bacon sizzling sound will commonly never cease. Besides the digital servo's centering noise I really don't understand the complaint(s) of excessive servo noise. Unless when maybe comparing an old analog type servo to a digital !? After running my 1230 for a bit... I really don't pay much mind to my servo's centering noise. And that's even with my HH BR/XL set in it's silent mode. IMO more annoying then the servo's centering noise... is the ESC's tones or beeps emitted during operation. |
04-26-2016, 06:02 PM | #12 |
Quarry Creeper Join Date: Jul 2015 Location: Menifee
I wont say nothing about the savox Taco lol. yes on the castle bec and I would get the bypass jumper RX Bypass Adapter - Wiring and Wiring Accessories - Electronics but you do need a castle link to program the bec Best thing I did was get rid of the stock dogbones and put in axial universals...way more steering Axial Wraith Universal Set next time you open it up it wouldn't be a bad idea to at least put a metal idler gear in the trans My stock knuckles and c-hubs seem to be holding up ok, so is the WB drive shafts....but like anything they will wear out and will need to be replaced. don't make the mistake I did on my scx10 and Loctite the plastic trans housing....stripped out the plastic when I removed it...had to get a aluminum housing |
Axial Wraith Questions & Help - Similar Threads | ||||
Axial wraith questions | Mikael | General Crawlers | 4 | 11-29-2014 10:04 AM |
Gmade R1 & Axial Wraith in Big Bear (Gold Mtn & John Bull trails) | 4x4LOYR | Videos! | 4 | 09-28-2011 03:53 PM |
