04-30-2016, 05:46 PM | #1 |
Newbie Join Date: Apr 2016 Location: Quebec Canada
| Hobbywing 3656sd cogging
Hi all, I just finished building a Wraith Spawn Kit and put a Hobbywing 3656sd 4000kv sensored motor with hobbywing 120A ESC. I tried it tonight for the first time and on 2s geared 56/16 it's pretty fast but it coggs pretty good whenever I try to slow crawl. The sensor cable was well connected so could my gearing be too high? I could go down to a 11 pinion gear would that help? Motor and ESC didn't run hot and I ran it for 1h on a 5800 mah 2s lipo Tunigy nanotech pack. Any recommendations? |
04-30-2016, 06:57 PM | #2 |
Rock Crawler Join Date: Oct 2013 Location: Wiscasset, ME
| Re: Hobbywing 3656sd cogging
I never had any troubles with this combo. 56/16 gearing is a bit much. 11 pinion is a good place to start. Could also be some ESC settings. The HW 120 ESC isn't the smoothest ESC to begin with either. |
04-30-2016, 09:37 PM | #3 |
Probably a bad sensor cable or sensor board.
05-03-2016, 05:10 PM | #4 |
Quarry Creeper Join Date: Jun 2013 Location: South jersey
Try to find a MMP. I run an 11t pinion and it's smooth as glass.
05-06-2016, 06:55 PM | #5 |
Just switched to a 11T will try to get out on the weekend and see if it makes a change. I had dyalectric grease on both ends of the sensor so maybe it came a bit loose. It's in tight on both ends so will see if there is a change.
Hobbywing 3656sd cogging - Similar Threads | ||||
Hobbywing Power | SCT Pro + 3656sd 3400kv | treys1 | Axial Wraith | 7 | 09-06-2015 05:39 AM |
Hobbywing 3656SD 4000KV motor questions | IPT | Electronics | 0 | 05-14-2014 10:41 PM |
pictures w/ caliper HobbyWing 3656SD rotor size larger than Tekin Pro4 and Tenshock | ussprinceton2004 | Non Crawler RC's | 0 | 02-24-2013 08:35 PM |
