05-02-2016, 09:56 AM | #1 |
Pebble Pounder Join Date: Aug 2014 Location: Dunkirk, NY
| VP Scale / Incision / Regular CHUBS/KNUCKLES
Looking at what to get for the curries as far as internals. 1. which should I run? Incision chubs and knuckles or the "scale" versions? I am going to be running the vvd's in the front if that matters. 2. I can just run the stock axle shafts in the rear? 3. as far as lockers and gears... what is the top 2 lockers? VP and what else. I was thinking about the GripFab ARB Locker? Is that a good part? 4. with the lockers do I still need to buy the crown and pinion gear? Where should I be getting those from? |
05-02-2016, 10:07 AM | #2 |
| Re: VP Scale / Incision / Regular CHUBS/KNUCKLES
You've started 6 threads that I see on the first page. You'd be amazed what a little research would accomplish with your questions. And I mean that in the nicest way. In other words, spend some time using the search feature. Might speed things up for ya. |
05-02-2016, 10:32 AM | #3 |
I wanna be Dave Join Date: Apr 2015 Location: Roseville, Ca
If you want to run knuckle weights then get scale chubs and regular knuckles. If you aren't going to run knuckle weights then get scale chubs and knuckles. Yes stock rear shafts are fine. Locked up or blue monkey makes no slop lockers. Crown and pinion gears for locker? Not sure what you mean.
05-02-2016, 12:09 PM | #4 | |
| Re: VP Scale / Incision / Regular CHUBS/KNUCKLES Quote:
36/14 or 38/13 suffice? Axial Racing Heavy Duty "Overdrive" Bevel Gear Set (36/14) [AXI30401] | Parts - AMain Performance Hobbies Last edited by slapjack; 05-02-2016 at 12:34 PM. | |
05-02-2016, 01:49 PM | #5 |
Overdrive gears have the worst mesh so I wouldn't get those. Either HD standard or HD underdrive gears. The underdrive gears have the best mesh, easier on parts and helps with torque twist. The puller pro 3500kv is a great choice.
05-02-2016, 02:04 PM | #6 |
Knuckle weights don't work with scale knuckles, they work with regular vp knuckles. Bang for the buck hands down is regular vp knuckles, vp clamping scale knuckles, holmes cromo lockers with hd stock ratio front and under drive rear. Source it all drop dluxfab.com and you'll save a pile of cash. |
05-03-2016, 02:23 PM | #7 | |
Also with the underdrive gears in the rear, how does that work if the front is turning faster than the rear? I can see that working good in crawling situation but what about just cruising around, bashing or whatever? Will it be ok with that setup? | |
05-03-2016, 04:14 PM | #8 | |
Yes I meant clamping c hubs not knuckles. I'm dumb so I screw up sometimes. Yes clamping scale knuckles work with standard knuckles. Yes you can run weights on the knuckles later if you wish. There isn't a huge gap between stock and under drive gears so while it helps crawling it doesn't hurt the bashability of the rig. I run HD/UD in my basher and bouncer. | |
05-03-2016, 04:50 PM | #9 |
Thanks... What about locker vs spool. What is the difference? Bevel gear still mounts to the top of the spool like the locker right? But what's the difference between the 2?
05-03-2016, 04:53 PM | #10 |
Locker and spool are interchangeable terns in this situation.
05-03-2016, 05:43 PM | #11 |
What do you mean? They are different parts it looks like to me. I'm talking about the vanquish spool. They have a thing where u get a free spool when u buy an axle. It is a single piece part and looks different than the vanquish locker. Are they the same just the spool is made from a single piece of steel compared to a 2 piece design of the locker?
05-03-2016, 05:50 PM | #12 |
Lockers and spools do one thing. They lock the axles together and do not allow the rear tires to turn at different rates as an open differential would. VP has a locker with set screws to hold the shafts thats in an aluminum housing and they have a locker that's one piece of steel that the axles slide into that locks them together. |
05-03-2016, 07:09 PM | #13 | |
05-03-2016, 08:34 PM | #14 | |
Basically yes. All slip fit lockers function the same whether it looks like a spool or an arb locker. I have a vp 2 piece locker in my basher. It's fine but the screws ce loose over time even loctited in place so I've gone to holmes 1 piece lockers. | |
05-03-2016, 08:54 PM | #15 |
Quarry Creeper Join Date: May 2014 Location: United States
you want a one piece spool over a diff case with a locker in it less slop is better go with locked up rc fi spool |
05-03-2016, 09:13 PM | #16 |
Is the incision spool no good? Like I said they are including one with the purchase of a both axle.
05-03-2016, 10:23 PM | #17 |
There is zero reason to go with one brand of 1 piece locker over another when they're all made of the same material. Especially when someone will throw one in for free. |
05-04-2016, 06:10 AM | #18 | |
In this situation, searching VP, Vanquish, Chubs, Knuckles, scale all pull up the items youre looking for. Here are all the version of chubs and knuckles you could possibly want at the best prices you will find. Dlux Fab Dlux Fab Dlux Fab Dlux Fab Dlux Fab | |
05-04-2016, 06:57 AM | #19 | |
05-04-2016, 07:45 AM | #20 |
Knuckle weights and big bearing knuckles... sounds like a set of brass knuckles are right up your alley.
VP Scale / Incision / Regular CHUBS/KNUCKLES - Similar Threads | ||||
vp scale chubs/knuckles or stage 1 kit? | db450 | Axial Wraith | 4 | 06-02-2014 04:25 PM |
