05-06-2016, 09:34 AM | #1 |
Pebble Pounder Join Date: Aug 2014 Location: Dunkirk, NY
| SSD Parts Questions
I was just curious... Do the SSD Chubs work with VP Curries? SSD Wraith/RR10 Pro Aluminum C Hub (Grey) (2) [SSD00107] | Parts - AMain Performance Hobbies Do the axle shafts work with vp curries? SSD Wraith/RR10 HD CVD Axle Set [SSD00093] | Parts - AMain Performance Hobbies Can the 2 speed tranny be used with the super shafty beefy top shaft for use with the RR slash slipper? Any chance the super shafty 6mm outputs would work in it also? |
05-06-2016, 10:52 AM | #2 |
RCC Addict Join Date: Oct 2014 Location: UK
| Re: SSD Parts Questions
Yes SSD C hubs & CVDs should fit any othetr brand Ar60 type axle. The 2 Speed is compatible with the stock top shaft so if the SuperShafty top shaft fits the stock tranny it should also fit the SSD 2 Speed. Outputs are completely different as it is a 2 Speed. |
05-08-2016, 10:12 AM | #3 |
Couple other questions... would my vp knuckles mate up ok with the ssd chubs or ssd knuckles work with vp chubs? I'd assume they would. Ssds aren't clamping are they?
05-11-2016, 01:20 PM | #4 |
| Re: SSD Parts Questions |
SSD Parts Questions - Similar Threads | ||||
SSD Axles Parts | n_d_fox | Axial SCX-10 | 19 | 04-08-2016 01:44 PM |
SSD knuckle and c-hub questions | dpcardoza | Axial SCX-10 | 2 | 03-30-2016 10:28 AM |
SSD Parts on SCX10 ??? | n_d_fox | Axial SCX-10 | 20 | 03-17-2016 12:07 PM |
SSD - Wraith Axle Option Parts | SSD | Axial Wraith | 60 | 04-17-2015 09:31 PM |
