05-14-2016, 08:03 PM | #1 |
Rock Stacker Join Date: Mar 2016 Location: Nashville
| BEC/Steering Question
I'm running a 7950 and just installed a Castle BEC at 7.4 and HH Bypass adapter after not having much luck with a No Brainer. In all fairness, I think I might have a bad No Brainer. Anyway, the Castle seems to have made the steering a lot stronger and a lot more predictable, but it will still lag a split second or 2 every now and then. Sometimes at speed, and sometimes on the rocks. All other times, it's lightning fast responsive. I'm running the stock RTR ESC, TX and RX. What should I expect out of it? It will still sometimes bind up in the rocks and not be able to turn. Is that normal, or should I expect the steering to have the balls to push the truck in almost any situation? I'm running titanium links and all metal parts so no give there. Thanks!
05-15-2016, 01:06 AM | #2 |
| Re: BEC/Steering Question
are you sure your CCBEC's output is producing 7.4v ? did you check the BEC's voltage output using a voltmeter to be sure ? Did you change the CCBEC voltage default setting using the CC link ? Or was that done for you ? You're positive the CC link was connecting with the CC link correctly... And that the setting(s) adjusted in fact were saved during re-programming ? I have some experience using both the CCBEC and HH's RX by-pass "Y" I utilize them on both my 1/10 and 1/6 crawler's. I've never had issue running either. Granted I don't run the 7950, but it's a respectable amount of torque so doubt I'd think to fault the componets if they were fresh/new. plausibly a set up/programming issue, would be my guess. Last edited by TacoCrawler; 05-15-2016 at 01:43 AM. |
BEC/Steering Question - Similar Threads | ||||
Wench and Steering on one BEC... | Greatscott | Electronics | 7 | 06-18-2011 03:23 PM |
Cc bec vs steering issues? | SwampDawg | Electronics | 18 | 11-04-2010 05:36 PM |
MRC Four Wheel Steering BEC Question | SMR 510RR | Electronics | 4 | 07-01-2010 07:27 PM |
BEC and Steering Mystery | Harvo | Electronics | 3 | 08-01-2009 10:51 AM |
