Thread: Removing receiver from Receiver box
Old 05-17-2016, 06:50 AM   #1
Default Removing receiver from Receiver box
I have a Spawn RTR that I making a few mods to Can the receiver be easily removed from the receiver box? It seems to be pretty solidly fastened in (glued?). And I don't want to damage the receiver box in the process. If this can be done, how do I go about doing it?
Thanks!
alank is offline   Reply With Quote
Old 05-17-2016, 09:08 AM   #2
Default Re: Removing receiver from Receiver box
Should just be double sided taped into the box.
Steve p is offline   Reply With Quote
Old 05-17-2016, 10:26 AM   #3
Just twist and pull.
SCREAMER is offline   Reply With Quote
Old 05-17-2016, 10:45 AM   #4
Yep! ...and if you leave it out in the sun, it may warm the adhesives a bit to ease the task....
sixtyspokes is offline   Reply With Quote
Old 05-17-2016, 11:30 AM   #5
Thanks!
As for sitting in the sun ... I think our sun needs to warm up a tad. Kind of chilly here the past few days, even for Minnesota
Right now my rx in box is where the battery was, battery has moved to the front, and NVS is in front. I have Da Tray/Da Cover on the way and was planning to put rx back in front nd NVS in the Da Tray. But sure would save a bunch of work if I left NVS in front and put it in the receiver box. Does anyone know if that would fit? Then put rx in the Da Tray. Thinking about putting the ESC in there too.
Removing receiver from Receiver box - Similar Threads
Receiver Box? Truckmechanic304 Electronics 4 04-06-2016 02:08 PM
Shortcut to receiver box avoidsthelight Axial Wraith 11 07-28-2011 05:14 PM
who's using traxxas receiver box? chicostaxxs007 General Scale Talk 6 07-02-2011 11:57 AM
Trying to get the receiver out of the receiver box rock-gobbler 77 Electronics 6 03-03-2011 04:03 PM
slash receiver box callahanc83 Axial SCX-10 9 06-24-2010 05:14 PM
