06-01-2016, 03:42 PM | #1 |
Quarry Creeper Join Date: Dec 2015 Location: Sutter
| Help choosing appropriate motor.
1.9 wraith weighing 8-9lbs ish. 13t crawl master vs 27t torquemaster. General crawling with a mix of trail runs. Don't fully understand the torque vs rpm applications. Sent from my iPhone using Tapatalk |
06-01-2016, 03:46 PM | #2 |
Quarry Creeper Join Date: Mar 2015 Location: Woodland
| Re: Help choosing appropriate motor.
you will probably be happy either way, I have the torquemaster in the same falvor. its pretty awesome motor, it woud say crawlmaster if youre leaning towards crawling, and torquemaster if more trailing
06-01-2016, 04:01 PM | #3 |
yep, let the name guide you. Crawlmaster has better low speed control, very refined feel. The TorqueMaster has more grunt, and starts up smoothly enough to use in technical terrain. I only use 13t or 11t CrawlMaster in my personal rigs. |
06-01-2016, 04:14 PM | #4 |
Rock Stacker Join Date: Apr 2012 Location: zeeland
I'm new to the scale crawler scene and am in the same situation. Don't know what motor to get. I would like something with enough wheel speed for climbing sand hills but still have low end control and torque for the rocks. I'm leaning toward the crawl master but don't know if it will have enough wheel speed. Maybe I will get both! What would the 11 turn be equal to in a 3 slot motor turns? Last edited by THX_138; 06-08-2016 at 09:46 PM. Reason: Merge, posts seconds apart |
06-01-2016, 05:46 PM | #5 | |
| Re: Help choosing appropriate motor. Quote:
About a 23t in wheelspeed. It has a noticeable torque loss compared to the 13t, in the wraith you have to gear low. I prefer 13t for the wraith and 11t for scx10. | |
06-01-2016, 08:33 PM | #6 |
Thanks for the answers. I'm also looking at getting a 2 speed transmission and trying a torque master 550 21 turn.
06-01-2016, 09:14 PM | #7 |
Quarry Creeper Join Date: Aug 2014 Location: Chilliwack
| Re: Help choosing appropriate motor. What about if I'm running 2S? Would the Crawlmaster Expert 540 be to slow?
06-02-2016, 06:57 AM | #8 |
| Re: Help choosing appropriate motor. Slow is personal preference. You are better off running more gear reduction and 3s lipo than stock gearing on 2s lipo though. Volt up, Gear down. If you find our faster brushed offerings to be too slow on 2s, you always have room to go up in voltage. 2200mah packs are plenty big and also very cheap.
Help choosing appropriate motor. - Similar Threads | ||||
Need help choosing a motor for my trailfinder 2 | city hunter | Electronics | 6 | 12-12-2012 12:18 PM |
Choosing a motor | Hypn0t1q79 | Electronics | 6 | 07-03-2012 09:06 PM |
Choosing a Motor | Crawlercraig | Losi Micro-Rock Crawler | 5 | 03-07-2011 10:41 PM |
Need help choosing motor | Alex's revo 3.3 | Axial AX-10 Scorpion | 8 | 10-27-2009 08:29 PM |
help choosing motor | 671offroader | Axial SCX-10 | 9 | 09-04-2009 08:54 AM |
