Thread: LIPO question for wraithzilla chasis
Old 06-04-2016, 10:45 PM   #1
Default LIPO question for wraithzilla chasis
I am going to have a wraithzilla chasis in about a week and I am wondering where the best spot is to mount the electronics and LIPO. I am also wondering what mah 3cell LIPO I can get that will fit. I think Lue builds a cradle in the front area under the hood just behind the firewall so I think that is where it will be going.
I am also trying to figure out where to put the receiver. I was looking at theatres alum fuel cell from rc4wd. But I am also considering some other box that is waterproof. What is a good option? I will be conformal coating my Rx circuit board so I maybe able to still use the alum fuel cell but not sure yet
slapjack is offline   Reply With Quote
Old 06-04-2016, 11:33 PM   #2
Default Re: LIPO question for wraithzilla chasis
Check out my Wraithzilla build page Vera + Mattzilla = Verazilla!. I made an aluminum hanger to put the ESC and the battery straps in nicely up front. I shoved all the electronics in a rear mounted project box. A fuel cell might work if you just have a receiver.
mikebecher is offline   Reply With Quote
Old 06-18-2016, 10:34 PM   #3
What MAH 3s should I run? Will something like a 5000mah fit? Or even something bigger or will I need like a 2200 or something small like that?i will most likely have it under the hood area
Old 06-18-2016, 11:49 PM   #4
A 5000 mAh 3s definitely won't fit. I run these 2200s and there's some room to spare so you could go a little larger if you want, 2800 mAh should fit easily.
Old 06-19-2016, 01:15 AM   #5
I have a 3400mah hardcase that barely fits behind the firewall- it puts a bulge in the hood. I carry it as a spare. My 2200 lasts over an hour which is usually plenty for me. Its effin hot out!
DeviledEggs is offline   Reply With Quote
Old 06-19-2016, 11:16 AM   #6
Ok thanks guys. I guess I'll get a couple 2200s what brand is normal for crawling and trail riding? I come from a racing background and use mostly Smc, Trakpower, orca, etc... But I don't think they make that low of mah packs.
I found this. Is this what a lot of people use?
http://www.hobbyking.com/hobbyking/s...dProduct=57426
http://www.hobbyking.com/hobbyking/s...dProduct=59273
LIPO question for wraithzilla chasis - Similar Threads
question about soldering tubular chasis raolguio Newbie General 1 09-06-2010 01:44 PM
custom scale chasis question gosox1120 2.2 Scale Rigs 6 11-11-2008 11:17 AM
WK Chasis Question dresven HPI Wheely King 6 07-18-2008 09:49 AM
buidling a tube chasis. got a question damion289 Tools, and Procedures 8 02-11-2007 10:44 PM
tube chasis question? eaglesfn68 Newbie General 3 12-07-2006 02:56 PM
