06-08-2016, 05:21 PM | #1 |
Rock Stacker Join Date: Apr 2012 Location: zeeland
| Beef tubes?
Are beef tubes worth it or should I save up and get some ssd or vanquish axles housings?
06-08-2016, 05:31 PM | #2 |
Rock Crawler Join Date: Aug 2015 Location: Big Island
| Re: Beef tubes?
IMO they're worth it. I can't justify buying a set of VP or SSD axles when the lava rock I crawl on will just chew them up plus aluminum hangs up on it. If you're just looking for strength, Dlux axle trusses are also a good option.
06-08-2016, 06:58 PM | #3 |
Rock Crawler Join Date: Nov 2013 Location: In the country
| Re: Beef tubes?
Beef tubes and dlux truss for win. Sent from my LG-D850 using Tapatalk |
06-08-2016, 06:58 PM | #4 |
Thanks for the info mikebecher I will look into the dlux truss. My main issue with the plastic is the screws holding the C hubs coming loose or stripping out. Last edited by THX_138; 06-08-2016 at 09:41 PM. |
06-08-2016, 07:01 PM | #5 |
| Re: Beef tubes?
The screws will go into beef tubes making it solid Sent from my LG-D850 using Tapatalk |
06-08-2016, 07:11 PM | #6 |
Pebble Pounder Join Date: May 2013 Location: kinzers
| Re: Beef tubes?
I have beeftubes in front and rear vp axles easy low unsprung weight
06-08-2016, 07:45 PM | #7 |
Will a regular aluminum truss like the vanquish help strengthen the axle? Or would I be better off with the dlux carbon fiber truss? Last edited by THX_138; 06-08-2016 at 09:42 PM. |
06-08-2016, 07:57 PM | #8 |
| Re: Beef tubes?
If you want some low, unsprung weight (which you do if you're going to do any serious crawling) get some beef tubes. Trusses are a good addition for strength but don't do much for getting that center of gravity down, although the dlux trusses allow you to drop the servo which also helps.
06-09-2016, 11:23 PM | #9 | |
Quarry Creeper Join Date: Dec 2014 Location: The Angels
| Re: Beef tubes? Quote:
I run just beef tubes and stock trusses in my wraith. But I thought a snapped axle housing on the yeti warranted the full beef tube/ Dlux treatment. If you want to put the Dlux truss on the wraith, be aware that its taller so you might lose some up-travel. | |
06-09-2016, 11:50 PM | #10 |
| Re: Beef tubes?
Here's another vote for beef tubes and DLux trusses. I have this setup on two rigs and they both see hard driving, tumbles, crashes, cartwheels, and hard landings. Never had a problem from either truck. I'd also suggest adding DLux's modified AR60 housing for $20 so you can improve the internals reliability as well.
Beef tubes? - Similar Threads | ||||
need the O.D. of splined beef tubes or creation fab tubes please. | ctrwannabe | General Crawlers | 2 | 01-19-2016 06:06 PM |
Axle Tubes (Beef Tubes) | Bthomas | Arizona | 12 | 12-04-2013 11:27 AM |
