07-08-2016, 04:45 PM | #1 |
Rock Stacker Join Date: Apr 2012 Location: zeeland
| Wheel question
Will rc4wd wheels work with the axial 12mm hex? The reason I ask is my proline Titus does not unless I drill the wheel out a little. Also, do the rc4wd bead locks hold a bead really good? Sent from my iPad using Tapatalk |
07-09-2016, 06:22 AM | #2 |
I joined the Band! Join Date: Jul 2016 Location: United States
| Re: Wheel question
which RC4WD wheels are we talking about? I have a set of 1.9 wagon wheels and they hold the Axial Ripsaw bead just fine but won't hold Pro-Line TSL beads. Axial has two different hexes, one for the Wraith and most 2.2 wheels and one for the SCX10 and 1.9 wheels. sounds like the Titus could be 1.9 or use the SCX10 hex Axial Racing - 12mm Aluminum Hub (Black) Axial Racing - Axial Narrow 12mm Aluminum Hub - Black (4pcs) |
07-09-2016, 09:30 AM | #3 |
| Re: Wheel question
I'm wanting to get the race line monster wheels and the hexes I have are the ones in the first link. The Titus wheels I have are 2.2. The problem with them is the center hole is not big enough for the first shoulder on the hexes so it doesn't seat properly on the hex. Sent from my iPad using Tapatalk |
07-09-2016, 10:46 AM | #4 |
| Re: Wheel question
the Raceline Monster look to have the same hex as the Titus, you can either drill the center like you did with the Titus or buy the SCX10 narrow hexes in the second link. using the narrow hexes will shorten the track-width by 1mm on each side
07-09-2016, 11:35 AM | #5 |
| Re: Wheel question
Ok thanks Sent from my iPad using Tapatalk |
Wheel question - Similar Threads | ||||
wheel question | stampedecrawler | HPI Wheely King | 7 | 05-16-2010 06:29 PM |
~~wheel question~~ | 73formulabird | Tires and Wheels | 1 | 01-20-2010 07:09 PM |
wheel question... | austinquattro | Newbie General | 4 | 09-19-2008 05:24 AM |
HPI stock wheel/2.2 wheel beed--Question??? | tecnica2001 | Tires and Wheels | 6 | 10-26-2006 07:49 AM |
wheel question | wingnutcrawler | Newbie General | 1 | 08-29-2006 06:17 PM |
