Thread: Winch for Wraith
Old 07-09-2016, 10:49 AM   #1
Default Winch for Wraith
I have a 9.5lb Wraith and am looking for a scale winch to mount to a
Wertymade front bumper.
The specs on the RC4WD Warn are pretty anemic. What's the best choice in winches for this weight Wraith?
Thanks
chipgibbs is offline   Reply With Quote
Old 07-09-2016, 12:29 PM   #2
Default Re: Winch for Wraith
KMS, SSD, HeyOk
SCREAMER is offline   Reply With Quote
Old 07-09-2016, 12:59 PM   #3
I have the 1/8th scale Warn winch on my wraith works pretty well. It's probably close to yours in weight.
Sent From My Galaxy S6 Edge+
sharkattack99 is offline   Reply With Quote
Old 07-15-2016, 08:19 AM   #4
i made my own winch yesterday i used my stock stering servo for a winch i just pulled the pin out and removed the plastic potensiomitor holder and used the servox large round servo horn and a small round servo horn and a long bolt and mounted it where my reciver box was originaly it easily dead lifts the wraith i watched the youtube videos they all made it seem so complicated solder here unsolder here add this cut this off i only modded the one gear that the servo horn mounts to put it back together done i searched ebay for a winch for the 10-15 range rig and couldent find anything so i decided to make one i gathered up a 380 motor some gears when i found a stock ae3 servo i figured ah why not give it a try it worked great i had to turn it down a bit because it had way to much power the tactic 300 dosent have many options for the 3rd channel so the controls are alittle clunky other than that its great
ferp420 is online now   Reply With Quote
Old 07-15-2016, 10:16 PM   #5
a quick vid of testing the home made winch
https://youtu.be/2EjviyfukM0
Old 07-25-2016, 01:05 PM   #6
Do any of these have a defined duty cycle? Sounds like a crazy question but my 5yo has been asking for a winch for his wraith however once he gets it he will try and winch everything from his truck to his little sister. I am worried he is going to burn it out in a day.
JeremyFXDWG is offline   Reply With Quote
Old 07-25-2016, 01:28 PM   #7
I guess my first question is, how does a 5yr old get a Wraith??
rcmattster1971 is offline   Reply With Quote
Old 07-25-2016, 02:56 PM   #8
Best one today!
valheru is offline   Reply With Quote
Old 07-25-2016, 07:25 PM   #9
The same way my 10month old got a Bomber
rngrchad is offline   Reply With Quote
Old 07-25-2016, 08:01 PM   #10
Lol. Yea. He knows I am easy. When he asked to build a RC off-roading trail around the yard I caved. His little 1/24 scale Trail Trekker was not cutting it.
Winch for Wraith - Similar Threads
Winch Bumper for the Wraith CamposZac96x Axial Wraith 13 09-13-2014 05:18 PM
winch on a wraith?? SwampDawg Axial Wraith 2 09-28-2012 09:04 AM
Winch On Wraith teamvaladezhobb Axial Wraith 10 08-08-2011 05:06 PM
Wraith winch Burn General Crawlers 0 07-03-2011 05:55 AM
