07-13-2016, 03:03 PM | #1 |
Rock Stacker Join Date: Jun 2013 Location: Riverview
| Need recommendation on a droop kit
Does anyone make a kit that doesn't require butchering the hood? Thanks in advance.
07-13-2016, 07:40 PM | #2 |
RCC Addict Join Date: May 2013 Location: Forrestfield, Western Australia
| Re: Need recommendation on a droop kit
Gearhead lowering kit from RPP is cheap. Gear Head RC Wraith Droop - Lowering Kit The front plates will come through the hood but being delrin are easily cut so you could just take off as much as you need to be under. |
07-14-2016, 09:03 AM | #3 |
Quarry Creeper Join Date: Apr 2014 Location: a land bereft of rocks
Ckrc makes a wraith droop kit that doesn't require cutting.
07-14-2016, 09:24 AM | #4 |
Great I have a level3 and it requires cutting the hood. I'll check it out, thanks. Sent from my LGL16C using Tapatalk |
07-14-2016, 09:47 AM | #5 |
Rock Stacker Join Date: Jan 2010 Location: moreno valley,ca
Why not just limit your shocks?
07-14-2016, 12:38 PM | #6 |
Quarry Creeper Join Date: Mar 2015 Location: Woodland
| Re: Need recommendation on a droop kit |
07-21-2016, 10:37 AM | #7 |
Rock Stacker Join Date: Mar 2013 Location: Chesapeake
In my opinion you don't need a droop kit. With proper shock set up and your shocks mounted in the right locations it will sit low. If you go to low you will drag your belly on everything. Sent from my SM-G900V using Tapatalk |
07-22-2016, 05:01 PM | #8 |
Pebble Pounder Join Date: May 2015 Location: CLAYTON, CA
| Re: Need recommendation on a droop kit This is the CKRC droop kit installed. Had to cut hood but really only for the G-Made Piggyback shocks due to the reservoir. Plate itself didn't really push above hood when closed. Probably could have gotten away without cutting the extra slots on hood with the Ol' Dremel. Hope this helps. Hood is Dinky RC. Sent from my iPhone using Tapatalk |
07-24-2016, 10:06 PM | #9 |
Pebble Pounder Join Date: Dec 2013 Location: central
Can someone please explain to me why they call a lowering kit a droop kit? Droop refers to the uptravel at ride height being minimal, therefore most if not all of the travel happening during droop. A lot of this can be done simply by raising the spring adjusters, but remember, you still need spring tension to full extension to drive the shock out when needed. Different/softer spring is usually needed to accomplish this properly. Now if you are lowering the chassis by raising the shock mounts so the axles hit the chassis before the shocks are at full compression, you are wasting shock travel. With all of that said, there are 2 schools of thought to uptravel vs droop only. In a full droop setup, the tire must pick up the full weight of the rig at that corner to climb the obstacle. Some say that weight improves traction given to that particular tire. The other school of thought is, having uptravel reduces the amount of weight the tire needs to lift to climb the obstacle. In my opinion, full droop setups tend to work best on areas that have more steep, flat climbs, while more uptravel tends to work better in areas where ground clearance is key like small rocky areas.
Need recommendation on a droop kit - Similar Threads | ||||
Droop kit recommendation | novarider | Axial Wraith | 26 | 06-09-2015 10:46 AM |
Lift Kit or Droop Kit? | LBrown867 | Axial SCX-10 | 6 | 04-28-2014 11:42 PM |
Best droop kit | Chesebro | Axial Wraith | 6 | 06-25-2013 05:09 AM |
Droop Kit | Madkiki | Axial Wraith | 6 | 12-06-2012 04:30 PM |
Took Kit Recommendation Wanted/Needed | getoutandplay | Losi Mini-Rock Crawler | 3 | 11-29-2008 08:04 AM |
