Thread: Locker
Old 08-22-2016, 08:31 AM   #41
Default Re: Locker
Originally Posted by NWHavok View Post
Heads up for you Maxx, I ran those spools on 4S 3500kv Holmes motor with Vanquish VVD's and sheared the tabs off 3 axles in 2 weeks inside the spools.
That might have something to do with the insane 4s power your running! I'm running a roc412 on 3s so I'm guessing I won't have that problem.
MaxxCrawl is offline   Reply With Quote
Old 08-22-2016, 09:11 AM   #42
Default Re: Locker
I picked up the BMRC 2 for 1 deal too for the bomber. Not nearly as tight as the FI spools in my wraith. Video of them when new in the front using axial universals. The rear isn't really any tighter either.
Click for video
http://s36.photobucket.com/user/mnor...03324.mp4.html
MNorby is offline   Reply With Quote
Old 08-22-2016, 10:21 AM   #43
Default Re: Locker
Originally Posted by Drm31078 View Post
Just got a set of Grip Fab SS spools, brass beef tubes, and VP chromoly rear shafts. Just finished installing it all...then I read this. Now I am nervous I ground down the shaft lip too much for the beef tubes! They barely fit through the beef tube, so I should be okay.
People have good experience with the Grip Fab spools? They seem to be around for a while and only $23 isn't bad.
Grip Fab spools are great. I've been running a pair for 5-6 months now in my brushless Wraith and no problems at all. I also had a chance to work with the vendor who makes them and his customer service was top notch. You chose wisely.
SCREAMER is offline   Reply With Quote
Old 08-23-2016, 07:44 AM   #44
Default Re: Locker
LOL, surprisingly enough I never broke anything while giving it throttle. Every single one broke when I came to a sudden stop. My guess is rotational weight/force was the factor. Upgraded to Dlux FBA axles and haven't looked back!
NWHavok is offline   Reply With Quote
Old 08-23-2016, 11:24 AM   #45
Jus
Default Re: Locker
Hot Racing spools used to be my favorite cause they are simple, strong, and cheap. They have since creeped up in price so now for a few dollars more the LURC FI spool is a wayyyy better deal. Best spool out there IMO.
Jus is offline   Reply With Quote
Old 04-26-2019, 05:18 PM   #46
Default Re: Locker
Bringing this post back alive and wanted to ask if anyone has pics of the Locked Up RC spool installed in their Wraith.
offroad1911 is offline   Reply With Quote
Old 04-26-2019, 05:43 PM   #47
Default Re: Locker
I could take a pic but it's packed with marine grease. Any specific thing you are looking for?
Sent from my SAMSUNG-SM-G920A using Tapatalk
Steve g is offline   Reply With Quote
Old 04-26-2019, 10:13 PM   #48
Default Re: Locker
Not much to see, but I snapped this for you just now, hopefully I wiped off enough grease for you to see what you're looking for. That's a LURC heavy weight F.I. spool in the front of my Wraith. I also have the standard weight and Vanquish/Incision spools in various cars and they are all of similar quality, the Incisions are probably a few grams lighter than the others (speed holes!) but the F.I. spools are definitely the tightest fitting.
TheLetterJ is offline   Reply With Quote
Old 04-27-2019, 12:15 PM   #49
Default Re: Locker
I appreciate you taking the time to do that. It's exactly what I needed to see.
Locker - Similar Threads
Has any one else had there HR locker do this? MacJamez Vaterra Twin Hammers 8 05-26-2014 08:07 PM
locker hodges996 Axial AX-10 Scorpion 7 02-18-2009 01:36 AM
Best locker RockCrawlingKid HPI Wheely King 17 02-01-2008 03:04 PM
Need a locker or 2 Golfcrawler General Crawlers 1 01-26-2007 08:27 AM
