08-07-2016, 06:55 PM | #1 |
Newbie Join Date: Aug 2016 Location: graham
| motor and esc
Sorry for another one of these posts, i have been reading a few days and just joined. I have a ps wraith and i want to install a hh puller pro. What kv do i want, 3500 or 4500? whats the difference? And a mm seams to be the esc to go with. Thanks for your time.
08-07-2016, 06:58 PM | #2 |
Quarry Creeper Join Date: Aug 2015 Location: canton,oh
| Re: motor and esc
hh puller pro 3500 kv xl and a ble works great in my wraith |
08-07-2016, 07:10 PM | #3 |
I wanna be Dave Join Date: Dec 2006 Location: here
| Re: motor and esc
Better hope your drivetrain is up to the power of HH xl 3500KV.. lol.. I run HH 3500kv xl in my Yeti great motor.. 3s lipo.. |
08-08-2016, 06:08 AM | #4 |
| Re: motor and esc
How long run time on a HH pp not the xl? And please describe to me what i would want in kv, the 3500 or 4500 and why.
08-08-2016, 10:08 AM | #5 |
Newbie Join Date: Jan 2016 Location: Huntsville
| Re: motor and esc
You might check out Harley's sticky: Choosing a motor and ESC for your Wraith - Gearing Added! |
08-08-2016, 12:17 PM | #6 |
| Re: motor and esc
If you're using your Wraith for crawling and/or don't have a bombproof driveline, the Puller Pro XL is an awful choice. Really guys? That's your first recommendation for the noob? Awful low speed control and parts annihilating torque. Matthew, why don't you tell us what you are intending to use your Wraith for. As far as KV goes, the higher the number the faster the motor. IIRC KV means 1000 RPMs per volt.
08-08-2016, 12:30 PM | #7 | |
Rock Crawler Join Date: Aug 2007 Location: Philadelphia
| Re: motor and esc Quote:
08-08-2016, 01:33 PM | #8 |
| Re: motor and esc
I want to crawl some and then 4 wheel drift it. I'm looking at the non xl. What kv should I get? Thank you. And will I still get good run time. I run a lipo 5000 2s now.
08-08-2016, 01:43 PM | #9 |
| Re: motor and esc
You'll get plenty of runtime out of a 5000mah battery when crawling. Going full throttle bashing will drop your run times significantly but crawling should give you at least 2 hours out of that pack. I'd suggest that if you do 50% or more crawling to go with the 3500. If you'll be spending more of your time going fast, I'd say the 4500 is better suited for you. Or you can have the best of both worlds and run 2s for crawling and 3s for bashing. It's like having both motors.
08-08-2016, 02:35 PM | #10 |
Quarry Creeper Join Date: Mar 2016 Location: Midlands
| Re: motor and esc
I found the thread 'puller pro lays down the power' in the holmes hobbies vender section was very useful too. For 2s, the 4500 will look like the best choice, since you will get closest to the full 50k rpm motor limit, which, as i read it, means you will get most effective use of the motor. 3500kv gives you safe 2s and 3s use, with the 3s giving you a step up in power.... But 3500kv's seem to be out of stock. I just bought a 2700kv, currently on 3s. My stock 12/56 gearing is too low and slow for my taste. I think a 14 or 15 pinion will have the beast doing some satisfying leaps. I'll maybe go 4s at some point... But for now i'm loving the new motor. |
08-08-2016, 04:17 PM | #11 |
| Re: motor and esc
Thank you all. Forums been great. Pirate 4x4 knowledge with jeep forum attitudes.
08-08-2016, 05:03 PM | #12 |
Pebble Pounder Join Date: Aug 2015 Location: Red Hill, PA
| Re: motor and esc
I personally got the Holmes Hobbies ESC and the trailmaster 3300KV motor, on 2s so far it has been doing great, I also followed the gearing recommendation for brushless sensored motors thats on here (hot racing steel super duty 32p 56t spur, robinson racing hardened 14t pinion). Unlike some people's experience I still have great low speed control. I shredded the stock transmission gears in about 5 minutes of running. After installing the axial metal set I also upgraded to MIP drive shafts. I haven't had an issue yet though with my axles, ring/pinion gears, or my transmission output. I will have to agree with some though, while going brushless is worth it, be ready to upgrade the drivetrain. Just my experience, mileage may vary! Last edited by Arctic Cat ZRT; 08-08-2016 at 05:10 PM. |
08-08-2016, 05:28 PM | #13 |
| Re: motor and esc
DBX, careful with 4s, it's so addicting. I used to run 3s and 4s on my Holmes 2200kv puller pro and it's fantastic. Now she just gets fed 4s. I think I'm hooked the same way I was when I made the switch from 2s to 3s. I just love that extra power always on tap. I've even started using 4s on my IFS Bomber running a Mamba Monster X and 3500kv puller pro. I just capped the max throttle at 90% in the ESC to try and stay under Max RPMs. These Holmes motors are amazing already, on 4s, they're phenomenal!
08-11-2016, 09:03 PM | #14 |
| Re: motor and esc
Anybody know when the motor will be in stock? I did email HH.
08-11-2016, 11:01 PM | #15 |
| Re: motor and esc
was supposed to be about a week away. Just got an update that it will be the end of the month. I tried to not run out of stock on the 3500s, but when I posted that stock was getting lower we had people make a run on inventory and wipe us out. I would probably say 3500kv, but that is my go-to choice for almost every single rig. A 2700 or 4500 would also have the flexibility to do what you want. |
08-12-2016, 08:13 AM | #16 |
Quarry Creeper Join Date: Aug 2013 Location: Wijnandsrade, NL
| Re: motor and esc
Jumping in on this as i don't want to make an unnecessary new thread. So i am building a class 2 hardbody rig with a full metal drivetrain. Even if i am thinking of keeping the stock 48P 87T spur and a 16T pinion (is my stock configuration, however 2 rigs have a metal spur. But the mayhem it makes!). In another comp rig i run a Tekin brushed combo on 3S and it's sweet. But for this i 've set my mind on a HH configuration. Like the BRXL esc and a Crawlmaster pro motor. Yet i am in doubt if it should be a 13T or a 16T. She will run on 3S (don't ask me why, i am just used to that). I like some buttersmooth crawling and a bit of wheelspeed when needed. What would your choice be? 13T or 16T? Your opinion and thoughts on this are appreciated! Last edited by MaFoDes; 08-12-2016 at 08:14 AM. Reason: Grammatical error |
08-12-2016, 10:24 AM | #17 |
| Re: motor and esc
13t. I have 2 of them, run them both on 3s, exactly what you described. Butter smooth low speed control and plenty of wheel speed even on my 1.9 rig.
08-12-2016, 03:35 PM | #18 |
| Re: motor and esc
Thanks! I will mirror the Tranny, so i guess i have to order it "Reverse"/clockwise. What would be the benefit of the 6 or 12 degree timing if it is already running clockwise? |
08-12-2016, 04:08 PM | #19 |
| Re: motor and esc
Advance timing gives a bit more power going forward and a bit less in reverse depending on how much timing is used. It's also easier on the motor and I believe it makes brushes last longer somehow.
08-24-2016, 09:55 PM | #20 |
| Re: motor and esc
Supershafty top shaft, and steel transmission gears installed, slash slipper 56t,14t pinion. Waiting on Holmes for the puller 3500. Drive line screw was rubbing supershafty motor plate, ground some off plate fixed that, also slipper is rubbing plate in one spot not badly but will that be ok?
motor and esc - Similar Threads | ||||
Sidewinder esc and 5700 motor or Traxxas vxl 3s esc with brushless motor? | THE CRAWLER KING | Newbie General | 6 | 08-22-2010 07:10 AM |
single motor esc or dual motor esc | jwo | Electronics | 0 | 01-20-2010 11:42 PM |
