08-21-2016, 06:10 PM | #1 |
RCC Addict Join Date: Aug 2014 Location: Virginia, Near DC, USA
| 30mm axle extenders?
I want to put HPI Savage wheels and tires on a Wraith, but the wheels have so much inward offset that I'll need axle extenders somewhere around 30mm-wide in order to keep the tires from rubbing. The only axle extenders I've seen that are wide enough look like they're pretty cheap, using a simple cross-pin to hold themselves on the axle and an O-ring to keep the cross-pin from falling out. Can anyone suggest a brand that's stronger, perhaps using barrel-bolts to hold the axle extender onto the axle? Unfortunately I don't think I can compromise on the width of the axle extenders at all.
08-21-2016, 09:38 PM | #2 |
Pebble Pounder Join Date: Apr 2015 Location: canada
| Re: 30mm axle extenders?
Ax 31290 Rear axle widener for ar60 axel. Should get you close |
08-22-2016, 02:34 AM | #3 |
Unfortunately I need a solution that fits the front and rear.
08-22-2016, 07:43 AM | #4 |
The front and rear Axel's are the same on the wraith. The kit above is for the rear of the yeti, which has the same axle as the wraith. |
08-22-2016, 01:16 PM | #5 |
The kit above doesn't contain CVD or u-joint axle extenders that work with the front steering knuckles.
08-23-2016, 06:37 PM | #6 |
Sorry about that I completely forgot about the front steering.
08-23-2016, 10:22 PM | #7 |
Yeah, that makes it more complicated. I got some 30mm extenders in the mail today, but I'm not impressed with their quality. I may have to go with shorter extenders and non-premounted tires installed in wheels with more offset, though I was hoping to avoid needing different wheels for this truck. |
08-24-2016, 08:50 AM | #8 |
RCC Addict Join Date: Aug 2013 Location: Missoula
Someone out there has wheels you can mount backwards to decrease the offset. No idea where I saw them though....
30mm axle extenders? - Similar Threads | ||||
junfac axle extenders? | driftah | Axial Wraith | 4 | 06-25-2014 11:10 AM |
wk axle extenders | chbronco | HPI Wheely King | 0 | 02-15-2013 01:28 PM |
Axle Extenders?????? | fantacmet | Losi Micro-Rock Crawler | 19 | 03-13-2011 11:18 AM |
axle extenders | goose ae | Axial AX-10 Scorpion | 14 | 12-22-2010 08:07 PM |
axle extenders | goose ae | Axial AX-10 Scorpion | 0 | 12-19-2010 08:39 PM |
