08-28-2016, 05:03 PM | #1 |
Quarry Creeper Join Date: Dec 2015 Location: Sutter
| Hot Racing Transmission
Anybody know if the scx10 transmission with the extended outputs would work on a wraith? Can't find anything one way or the other. Sent from my iPhone using Tapatalk |
08-28-2016, 05:28 PM | #2 |
I joined the Band! Join Date: Feb 2015 Location: On a rock
| Re: Hot Racing Transmission
The extended output should solve any issue of clearance I see no reason why it won't work just fine.
08-28-2016, 07:40 PM | #3 |
| Re: Hot Racing Transmission |
08-30-2016, 05:17 PM | #4 |
Rock Crawler Join Date: Jul 2010 Location: Great Britain
I have it and it's great.
08-31-2016, 07:49 AM | #5 |
08-31-2016, 01:12 PM | #6 |
Quarry Creeper Join Date: Dec 2014 Location: The Angels
For a wraith with an AX10 tranny, you can run either a standard output on the spur side and extended length for the front or extended on both sides. I run standard/extended outputs (6mm) with standard wraith MIPs. In hindsight, I would have used extended outputs on both sides as the screw shaft for the MIP is super close to the spur. Last edited by DeviledEggs; 08-31-2016 at 05:21 PM. |
Hot Racing Transmission - Similar Threads | ||||
Hot Racing 2 Speed Transmission | WT's Pauly | Axial Wraith | 16 | 07-14-2016 12:44 PM |
Hot Racing transmission | BigSki | General Scale Talk | 2 | 07-28-2009 06:25 PM |
New Hot-Racing AX-10 Transmission?? | Szczerba | Axial AX-10 Scorpion | 23 | 10-22-2008 06:25 PM |
