09-18-2016, 05:02 AM | #1 |
Newbie Join Date: Jun 2007 Location: Maine
| Winch Control
Can I use the third channel on my Tactic TTX300 to control the RC4WD 9.5 warn winch using the wired winch control? I have never tried to run anything off the third channel and the book that came with my P.S. Wraith gives information about the AX-3 not the TTX300
09-18-2016, 05:27 AM | #2 |
Rock Stacker Join Date: Jul 2016 Location: In the shadows
| Re: Winch Control
rcmaineiac- Yes you should be able to run your winch control unit off the tactic 3rd channel, as long as you do have the control unit. There are 3 different settings on the tx/rx- 2,3 and 4 position switching. Not sure on the programming as I read the info for the radio system before I installed it on my brother in laws rig, amd that was sometime ago, but I'm sure it will work. Google tactic radio system and download a user manual, that'll help lots! Good luck! Rock Farmer is Oscar Mike. |
09-18-2016, 06:11 AM | #3 |
| Re: Winch Control
Thanks so much for the info, will check it out!
09-18-2016, 06:44 AM | #4 |
Rock Stacker Join Date: Jan 2016 Location: goldsboro
| Re: Winch Control
i run my winch with a ttx300 and a heyok controller,bottom button in,top button out,double click to stop.never had any problems.
Winch Control - Similar Threads | ||||
Winch Control | DustyfX4 | Electronics | 9 | 12-06-2011 06:43 AM |
winch control | djmikeb | Electronics | 4 | 03-07-2011 08:25 PM |
