10-15-2016, 09:22 AM | #1 |
Newbie Join Date: Oct 2016 Location: Wheeling
| Painting wraith chassis
Hey guys first post here so I'm in the process of tearing the wraith apart to paint the chassis I've read a few of the post's on here about it but still have a few questions should I paint it assembled or piece by piece also what's your oppioins on clear coat thanks for the input in advance
10-15-2016, 11:12 AM | #2 |
Newbie Join Date: Dec 2015 Location: Québec
| Re: Painting wraith chassis
For me...i assembled And remove After all the screws...i use dip paint...so i Can touch up if scratch... Envoyé de mon Nexus 6P en utilisant Tapatalk |
10-15-2016, 01:04 PM | #3 |
So you left it assembled but removed the screws correct
10-15-2016, 01:32 PM | #4 |
I wanna be Dave Join Date: Mar 2013 Location: Minden
I turned one of my Wraith's into a 1.9'' rig with SCX10 axles And I painted my Wraith Chassis OD Green and mixed my own paint Took the chassis apart and painted the pieces by hand with a brush I also painted my Hutchinson beadlocks OD Green from a rattle can And like how it looks, but I have since parted out the Wraith Too use the parts and rims for 1/6th Scale Dragon Jeep Last edited by kgb424; 12-11-2018 at 01:27 AM. |
10-16-2016, 04:09 PM | #5 |
Looks nice I remember awhile back I used motor paint to paint a few plastic pieces on my ATV and they held up great so I think I'm going to try the same paint on the wraith what grit of sand paper would work the best
10-16-2016, 08:02 PM | #6 |
I used Rust-Oleum red primer and Forest Green paint, I bought at Home Depot, and painted the chassis with out sanding it On the wheels, I used a Scotchbrite pad to scuff them up a little and then used Etchless Primer and then Rattle can OD Flat Green and then I shot a little Flat Clear over the OD Green Scotchbrite pads work good for me Last edited by kgb424; 10-16-2016 at 08:08 PM. |
10-17-2016, 07:13 AM | #7 |
Pebble Pounder Join Date: Aug 2016 Location: Alabama
You can get spray paint that's meant specifically for plastic. I would stick with something like that. Make sure to follow the directions for proper adhesion. Also, I would hit it with a light coat of acrylic enamel for durability. You should be able to get a can that's matt finish, so that it's not shiny. |
10-17-2016, 08:46 AM | #8 |
Newbie Join Date: Dec 2011 Location: sl,ut
Deffently recomend something like krylon fusion spraypaint and a 2 part Urethane Clear Coat that comes in a spray can you push a button on the bottom to activate it. Much stronger clear coat and will help the paint last on the rocks
10-17-2016, 09:15 AM | #9 |
Thanks for all the info
Painting wraith chassis - Similar Threads | ||||
Wraith skins and painting questions? | riz | Paint and Body | 2 | 11-25-2013 09:48 PM |
Painting the Wraith body panels | jrowles91 | Axial Wraith | 2 | 10-10-2013 10:49 PM |
My Wraith just finished painting.!! | Hi-Intentionz | Texas | 0 | 05-05-2012 03:35 PM |
Painting the outside of a Wraith body. | sixOHfour | Paint and Body | 6 | 01-13-2012 12:26 PM |
