12-03-2016, 02:48 PM | #1 |
Newbie Join Date: Dec 2016 Location: US
| Rock bouncer vs. Low range crawler
Howdy, I just recently picked up a wraith rtr and other than replacing the servo and servo horn due to hucking jumps it is fresh out of the box. I am looking at all the options for what to modify and it seems everyone specializes between either crawling or rock racing. If I have to choose between the two I think I'll end up building a crawler, but right now I am having a blast doing both. I have set up some gnarly flexy crawls in my yard with the woodpile that require precise throttle control and tight turns where I barely get the tires spinning to make it through. I also have a steep, dusty hill in the yard that I climb full throttle-hammer down where the tires are spraying gravel and the truck bounces side to side, but eventually will climb. In a perfect world I'd have an SCX10 and a Yeti, but I could only afford to work on one so I got the wraith. An I screwing myself by not specializing or can I eventually modify my wraith to excel at both? This is my first RC car since I was 10yrs old and I'm having a blast taking it apart and ripping and rolling it around the rockies. Thanks for your help! |
12-03-2016, 04:22 PM | #2 |
| Re: Rock bouncer vs. Low range crawler
Without making a bunch of changes to alternate between both... the only viable option is to utilize a 2 speed transmission. I believe that 2 speed trans is available thru RC4WD called the A2 or something to that affect !? I don't know how durable it is tho' https://youtu.be/fj_uEbKtZyY otherwise retaining the stock transmission will find you gearing lower for crawl speeds... and gearing talling for wheel speed. I'll suppose the goal is to gear it inbetween so that you can crawl... but still have some wheel speed. I personally gear for the slower speeds... but still retain enough wheel speed to get up looser traction hills. But my top speeds never really exceed maybe 6 mph. Excessive wheel speeds just throws up more dirt and rocks when climbing loose terrain. Doesn't necessarily mean you climb up any faster. Now if ya make a run at it and hope to climb using momentum... the higher top speeds will be your game. If I ran a 2 speed trans... I'd likely gear it for slow... and slower But it all depends on what you want. |
12-03-2016, 04:50 PM | #3 |
A single speed trans can do everything with the right motor and battery selection. My bouncer crawler very well with a 2350 4 pole 1/8 scale motor on 4s. It would blast hills and jump nicely too. No extra bs, just a solid combo.
12-03-2016, 07:11 PM | #4 | |
| Re: Rock bouncer vs. Low range crawler Quote:
Add a sensored motor and geared correctly you can growl and fly..... Hang up and Drive | |
12-03-2016, 07:15 PM | #5 |
| Re: Rock bouncer vs. Low range crawler |
12-03-2016, 07:47 PM | #6 |
Quarry Creeper Join Date: Nov 2008 Location: grand junction
What white tr
12-03-2016, 07:47 PM | #7 |
White-Trash said
12-03-2016, 07:55 PM | #8 |
Pebble Pounder Join Date: Mar 2016 Location: GC
Id put 87t spur in and move the battery forward then call it good if you want stock driveline parts to last
12-03-2016, 08:18 PM | #9 |
I've got an scx10 with wraith axles did the 32p conversion 12t pinion and 56 spur run 3s brushed 13t Holmes motor it's great for both
12-03-2016, 08:19 PM | #10 |
What part of Colorado you from
12-03-2016, 08:24 PM | #11 |
12-03-2016, 08:26 PM | #12 |
Thanks guys, gonna probably run stock until Christmas and then work on the gearing/engine. Until then gonna try not to bash it too hard Sent from my SAMSUNG-SM-G900A using Tapatalk |
12-03-2016, 08:28 PM | #13 |
There's a bunch of guys on the front range area check out the regional section the crawl space has a cool indoor rock pile that they change up from time to time
12-03-2016, 08:38 PM | #14 | |
Sent from my SAMSUNG-SM-G900A using Tapatalk | |
Rock bouncer vs. Low range crawler - Similar Threads | ||||
Crawler or Rock Bouncer | mitchponton | 1:1 Full Size Vehicles | 7 | 06-07-2016 06:52 AM |
need low range gear | dhoffroad | General Crawlers | 6 | 02-05-2006 09:23 PM |
