02-05-2017, 02:43 PM | #1 |
Quarry Creeper Join Date: Dec 2016 Location: Sweden
| Wheel hubs Axial Wraith Spawn
Today I noticed that one of my wheel hubs had cracked. I have the Wraith Spawn which uses the AX80128 narrow wheel hubs. I was thinking about replacing these with aluminium ones but I assume that these will not work since the plastic ones are screwed into the wheel. https://www.kullagergrossisten.se/pr...-axial-wraith- https://www.kullagergrossisten.se/pr...r-axial-wraith Are there any aluminium wheels hubs that I can use? |
02-05-2017, 04:09 PM | #2 |
Newbie Join Date: Jan 2017 Location: Longview
| Re: Wheel hubs Axial Wraith Spawn Vanquish Products - Search Results for "hub" I believe these will work! Edit: Just noticed they don't have the slot for the pin...not sure if that's a deal breaker or not. Last edited by Smileythetrucker; 02-05-2017 at 04:13 PM. |
02-05-2017, 08:50 PM | #3 |
RCC Addict Join Date: May 2013 Location: Forrestfield, Western Australia
Solution is a new alloy hub but most of them, including the VP hubs linked above, require the 12mm hex you found initially. Either of the hex hubs will work but I'd go for those clamping style personally https://www.kullagergrossisten.se/pr...r-axial-wraith I'm not 100% on the length of the stock Axial hub but the Incision #3 should give you clearance at the knuckle/tie rod without being super wide. Incision Wheel Hubs #3 - Vanquish Products Last edited by altd896; 02-05-2017 at 08:52 PM. |
02-06-2017, 06:28 AM | #4 |
The spawn uses the same style hub as the yeti just look up yeti hub on eBay there are hundreads of them including the stock ones
Wheel hubs Axial Wraith Spawn - Similar Threads | ||||
Axial Wraith Spawn parts | screwy squirrel | Newbie General | 7 | 12-25-2015 10:07 PM |
Axial Wraith Spawn | Gurz29 | Axial Wraith | 9 | 01-09-2015 10:26 PM |
