03-15-2017, 06:55 AM | #1 |
Newbie Join Date: Feb 2017 Location: Atlanta
| AR60's - Incision Spools - Pinion Gear Spacers
I recently installed the Incision Spools on the front and rear. I have a feeling the new spools changed the backlash on the pinion/ring gear. I blew the front differential and wondering about spacing the pinion forward into the ring gear a little more. What is the best option? I have searched but can only find 1MM and I think that would be too much, not enough adjustability. Any input? Thanks in advanced |
03-15-2017, 07:25 PM | #2 |
RCC Addict Join Date: May 2013 Location: Forrestfield, Western Australia
| Re: AR60's - Incision Spools - Pinion Gear Spacers
For pinion shims you need a 5mm, https://www.amainhobbies.com/yokomo-...c-s50s/p270533 If you want to move the spool you'll need 10mm, https://www.amainhobbies.com/yokomo-...-s100s/p242340 |
AR60's - Incision Spools - Pinion Gear Spacers - Similar Threads | ||||
Incision/vanquish spools | Mitchell72 | Axial RR10 Bomber | 132 | 06-17-2018 09:50 AM |
Incision locker spools | Dialitic | Axial Wraith | 16 | 12-02-2016 01:31 PM |
trac-gear spools weak | flee | Tamiya TLT Crawlers | 29 | 09-07-2007 07:13 PM |
