03-18-2017, 01:29 AM | #1 |
Pebble Pounder Join Date: Apr 2011 Location: Hood river
| Wraith 2 speed...real or knock off rc4wd? AX2 2 Speed Transmission for 1:10 RC4WD Axial SCX10 Wraith Honcho RC Car Black | eBay Is this actually made by RC4wd? It says from China and says RC4WD? But its inexpensive... |
03-18-2017, 05:59 AM | #2 |
| Re: Wraith 2 speed...real or knock off rc4wd?
I doubt it's branded by RC4WD. But it's been debated that RC4WD contracts things from China. It may be the same thing but of lesser QC...or it may not be. Or it may just be a copy.
03-19-2017, 08:29 PM | #3 |
RCC Addict Join Date: May 2013 Location: Forrestfield, Western Australia
This is why it pays to read carefully ebay ads, it doesn't say anywhere in that ad that it's made by RC4WD or in any way a RC4WD piece, it says "AX2 2 Speed Transmission for 1:10 RC4WD Axial SCX10 Wraith Honcho RC Car" which in my opinion is a dupe to make it appear in searches looking for the genuine item & immediately makes me suspicious. It may be a complete repro/knock-off (where you take your chances on the quality/spares) or it could be a back-door sale by the factory that makes for RC4WD, only way you'll know is when they've already got your $$$$$ Last edited by altd896; 03-26-2017 at 09:41 PM. |
03-26-2017, 07:43 AM | #4 |
Pebble Pounder Join Date: Aug 2013 Location: near jax
Says it has a nylon gear.....
03-26-2017, 09:42 AM | #5 |
RCC Addict Join Date: Jul 2009 Location: Ontherocks
So you know... The real RC4WD AX2 does not have the dimples on the front output, rear output or upper bearing recess on the housing. I just looked at the AX2 in my wraith. I call fake; spend the extra coin for the real one |
03-26-2017, 06:05 PM | #6 |
Thanks guys. I'll stay away |
03-27-2017, 03:21 AM | #7 |
RCC Addict Join Date: Oct 2014 Location: UK
| Re: Wraith 2 speed...real or knock off rc4wd? |
03-27-2017, 09:21 AM | #8 |
| Re: Wraith 2 speed...real or knock off rc4wd? It says the larger gear is nylon. It also links to the metal gear which is simply the spur gear. It appears all of the gears in the transmission are metal. I wouldn't hesitate to buy this transmission. RC4WD stuff is Chinese. And it appears their supplier sells to others because stuff that looks exactly like RC4WD is sold by other vendors (RC Modelex, for example). |
08-14-2017, 03:52 PM | #9 | |
Pebble Pounder Join Date: Jun 2017 Location: United States
| Re: Wraith 2 speed...real or knock off rc4wd? Quote: | |
08-15-2017, 03:41 AM | #10 |
| Re: Wraith 2 speed...real or knock off rc4wd? Because other 2 speeds are not compatible with the Axial top shaft or Axial gear cover. So you cant use a different brand top shaft and you have to buy a gear cover. The SSD 2 speed solves this and as most users already have a stock transmission they can simply reuse parts they already have to complete the transmision. Thus making it cheaper. Also the SSD output shaft is HD.
08-15-2017, 07:02 AM | #11 |
Thank you for the clarification!
08-16-2017, 03:45 AM | #12 | |
I wouldn't be so quick to assume a copied product has been copied well. There are many grades of steel available and the copies usually use cheaper ones for gears and shafts or even cast parts. They probably dont know how to heat them correctly also. The may even use cast alloys instead of CNC machined aluminum for other parts. Also the copy factories wont be so particular about tolerances, fit and finish etc... I'm not here to defend RC4WD, just pointing out the real differences in original and copies. Whether it's SSD, RC4WD or VP copies they will all be inferior copies. | |
08-16-2017, 06:17 AM | #13 | |
08-16-2017, 08:26 AM | #14 |
Quarry Creeper Join Date: Feb 2014 Location: NNJ in the sticks
You're nit the first person I heard that from. My friend at the LHS has a RC4WD and hates it because every time he takes it out, something metal breaks on it.
Wraith 2 speed...real or knock off rc4wd? - Similar Threads | ||||
Wraith knock off scratch build | DonnieB | 2.2 Scale Rigs | 2 | 05-20-2013 08:42 PM |
