04-04-2017, 01:13 PM | #1 |
Quarry Creeper Join Date: Dec 2015 Location: Sutter
| Spur size
Right now I'm running the ssd transmission with a axial steel 56t spur. I would like to go up to a 60t spur. Does anybody run this combo know if it fits without outdrive interference? I assume the spur cover won't fit but want to see about outdrive clearance before pulling the trigger. Sent from my iPhone using Tapatalk |
04-05-2017, 11:31 AM | #2 |
| Re: Spur size
60t is the largest 32p spur that will fit inside the stock spur cover and won't have any outdrive or driveshaft interference. I ran this on an SCX10 of mine.
04-05-2017, 11:34 AM | #3 |
Pebble Pounder Join Date: Aug 2016 Location: Alabama
| Re: Spur size
That's a big difference, I'm running 87t spur but its what, 48p? Is that the other pitch... No fitment issues. Though, all of my housings are stock.
04-05-2017, 05:33 PM | #4 | |
| Re: Spur size Quote:
Thanks. That is what I was hoping to hear. Just wanted to here it from someone who has ran it before pulling the trigger on another $22 steel spur. Sent from my iPhone using Tapatalk | |
Spur size - Similar Threads | ||||
Spur Size | redliner | RC4WD Bully | 15 | 07-08-2014 06:02 PM |
Pinion and Spur shaft size question | 2Crawl | Axial Wraith | 7 | 10-12-2013 04:56 PM |
pinion and spur gear size | jcolvin | General Crawlers | 1 | 04-25-2012 10:13 AM |
Spur size with MIP and slipper | DMC | Axial AX-10 Scorpion | 4 | 12-17-2008 02:47 AM |
Stealth Clearance Problem/ spur gear size? | blue-beard | Newbie General | 15 | 06-26-2006 09:20 AM |
