05-14-2017, 07:35 PM | #1 |
Rock Stacker Join Date: Dec 2016 Location: Las Vegas
| hiding the servo on the front
I have seen a few Wraiths hiding the servo on the front. I love the look that it gives. Very Scale. However how does it preform? I understand having weight down low. but besides that how dose it effect flex?
05-14-2017, 11:36 PM | #2 |
RCC Addict Join Date: May 2013 Location: Forrestfield, Western Australia
| Re: hiding the servo on the front
Thats cms or chassis mounted servo, a search in here will find you a bunch of info. "Very scale" is debatable, in appearance maybe but not always operation, for a rig with full hydraulic steering like a comp truck it's less scale functioning, for a mod'd OEM truck with a steering box it's pretty scale. Depends entirely on what your building. The appearance is not without compromise though. It will result in a little axle swing from the panhard link but thats minor & not a total disaster. However if set up badly can result in bump steer & that is annoying. You can have some problems with the panhard interfering with the chassis depending on the set-up, that can limit axle travel. Kits are various so you'll have to research a bit to see what you like & can afford. |
05-15-2017, 06:00 AM | #3 | |
| Re: hiding the servo on the front Quote:
05-18-2017, 02:52 PM | #4 |
Rock Stacker Join Date: Oct 2016 Location: Petaluma
I have the VP setup. My Wraith is lowered, and this has created a problem with the panhard link. It hits on top of the axle, so I have very very limited front suspension movement. I am trying to figure out how to correct this.
05-18-2017, 04:27 PM | #5 |
If hiding it is your goal, how about hiding it BEHIND the front axle? Dlux offers a truss that does just that, offering more compression clearance for your front suspension, gets weight a bit lower, reinforces the axle housing, and I'm sure there are more benefits. It doesn't have the "scale" appearance that a panhard/CMS offers, but as stated, it closer resembles how a 1:1 fully hydraulic steering setup would swing. It's on my short list of remaining purchases for my Wraith: Dlux Fab |
05-18-2017, 06:33 PM | #6 | |
05-19-2017, 06:07 AM | #7 | |
The only difference is that the CMS or panhard is harder to setup and when youre done, the rig performs worse. | |
05-22-2017, 03:21 PM | #8 | |
I checked out you site on your truss to hide servo behind it but could not get a good image. Can you post some please? | |
05-22-2017, 09:52 PM | #9 |
| Re: hiding the servo on the front The full width trusses are aluminium now not carbon & the servo mount is slightly different but this is still pretty much how the dlux truss looks.
05-23-2017, 08:11 AM | #10 |
There are also a bunch more pictures on my site if you go to the product page. The pictures are below all the pricing options to buy. I just came out with some anodized/re machined versions too. https://dluxfab.ecwid.com/#!/AR60-Wr...unt/p/29404646 |
05-23-2017, 08:32 AM | #11 | |
10-18-2017, 09:49 AM | #12 |
Rock Stacker Join Date: Sep 2016 Location: Bolingbrook
does the U4 truss add as much strength as "Beef Tubes" do to the axle housing?
10-18-2017, 10:08 AM | #13 | |
It is also worth mentioning, the Dlux truss and Beef Tubes are not mutually exclusive options. They can be run together for the strongest setup a plastic housing could be. | |
10-18-2017, 01:56 PM | #14 |
I've been running the Dlux U4 front truss AND beeftubes for awhile now. After repeatedly bombing off of sand dunes (sometimes free falling as much as 20' before landing on the downslope or flat landing from 10'+) I can say that I'm not concerned with housing strength at all. I'll probably rip the shock mounting hardware out long before I need to worry about an axle housing. I also run the stock rear truss on the bottom of my front housing, I just thought it gave a little more authentic look to my Foff type Wraith, definitely wouldn't do that on a crawler but I don't need the ground clearance and it's got to help at least a little with housing strength. YMMV.
hiding the servo on the front - Similar Threads | ||||
What is your Government hiding from you! | EastsideZero | Chit Chat | 3 | 12-05-2012 07:33 PM |
Hiding wires? | rockassassin | Electronics | 2 | 02-04-2009 11:06 AM |
hiding the antena | rachad6 | Electronics | 5 | 01-29-2009 09:10 AM |
hiding steering servo? | Dubs Chops | General Scale Talk | 18 | 02-20-2007 07:15 AM |
