Thread: Slipper clutch issue
Old 06-20-2017, 08:36 PM   #1
Default Slipper clutch issue
My son was playing with his Wraith today on a dirt hill and started making a noise coming from the motor/tranny. Took it apart and found this:
Was the nut just too tight or does it have something to do with the new gearing/motor I put in it?
Punkin85 is offline   Reply With Quote
Old 06-23-2017, 12:53 AM   #2
Default Re: Slipper clutch issue
If anything I'd say the spring was too loose & it's been slipping too much & just chewed it too bits.
altd896 is offline   Reply With Quote
Old 06-23-2017, 07:30 AM   #3
Agree, your slipper was too loose and since the slip plate has holes in it, that's why it chewed threw the pad so quickly. A good rule of thumb for a slipper I've found is tighten it all the way and back off a quarter of a turn.
NWHavok is offline   Reply With Quote
Old 06-23-2017, 10:14 PM   #4
Integy junk strikes again! Yep the holes in the slipper plate acted like a cheese grader and shaved the pad right down.
I'd put the stock slipper/spur back on, or preferably grab the 32p slipper from the spawn/updated scx10.
MattTheGenus is offline   Reply With Quote
Old 06-24-2017, 07:36 AM   #5
That surprised me since it was tightened almost completely. Makes since about the holes acting as a cheese grader. I put the stock spur plate back on but kept the spur gear and pinion. From what I've read or online there seems to be varying opinions on just how tight to make the slipper.
Old 06-29-2017, 10:08 PM   #6
Or the simplest way by using this kit: Slipper Eliminator Kit - AX10 SCX10 Wraith
Good luck and cheers
Teng is offline   Reply With Quote
Old 06-30-2017, 12:33 AM   #7
The slipper in my Spawn kit works beautifully.
Ninomaniac is offline   Reply With Quote
Slipper clutch issue - Similar Threads
Tamiya XV-01 - slipper clutch setup and clutch pads Dims Rally 4 08-20-2017 01:19 PM
RRP Slipper clutch issue.. need input... tomvaillencourt Axial Wraith 14 11-09-2012 11:44 AM
MIP Driveshaft and Axial Slipper Clutch Clearance Issue kawika Axial AX-10 Scorpion 8 06-30-2008 07:56 AM
