TSS ar60 brass knuckles Just received my brass knuckles from the scale shop today and they look fantastic. The figment of them is perfect. Zero slop in the bushing and what I'm even happier about is the zero slop in the bearing raceways. I had to slightly tap the bearings into place. Far better than the vanquish knuckles these replaced. Hopefully they hold up over time but I'm guessing they will because they are very beefy.https://uploads.tapatalk-cdn.com/201...20a80b86fd.jpghttps://uploads.tapatalk-cdn.com/201...52c2e950d0.jpghttps://uploads.tapatalk-cdn.com/201...9b69590390.jpg Sent from my iPad using Tapatalk |
Re: TSS ar60 brass knuckles Congratulation to your new The Scale Shop Brass knuckles and maybe with the dlux no slop knuckle bushings? In my humble opinion, if your Wraith is heavy like mine ( 3.8kg ) then maybe it is better to put some grease inside the brass knuckle's holes and some in the knuckle bushings to prevent they wear out so quick like mine. ( Yes, They are Zero slop when they are new ) Read this thread for more information: http://www.rccrawler.com/forum/axial...ring-slop.html Cheers:) |
