07-16-2017, 10:53 AM | #1 |
Quarry Creeper Join Date: Feb 2014 Location: NNJ in the sticks
| Cheap and easy carbon strut tower braces
Go down to the LHS and pick up some carbon tube. The one I got was 5mm OD x 3.1 ID. The ID can be a little smaller to get more bite with the threads. Cut them to 55mm for the rear and 56 mm for the front. Make sure you account for the thickness of your cutting tool. I used a dremel cutoff wheel and sanded it down to final on a belt sander. A thin kerf saw and a miter box would probably be better but I didn't have them were I was. Find some longer screws for the upper shock mount and just place the rod in-between the towers and screw it into the rod. I used the coarse screws as they seemed to have better bite but a machine thread should work is you can find rod with a smaller ID. |
07-16-2017, 12:25 PM | #2 |
| Re: Cheap and easy carbon strut tower braces
Here's some pictures. You will need some 3mm screws that are about 35-36mm in length if'you're going through the shock mounts at least in my case. The 30mm ones I used in the rear just barley engage so I'll have to visit the LHS to hopefully find something that will give it more thread engagement. |
07-19-2017, 10:27 AM | #3 |
Is there any noticeable difference with or without? I have some carbon arrows I was considering doing similar for the rear braces since the battery tray isn't there any more.
07-19-2017, 12:30 PM | #4 |
Quarry Creeper Join Date: Dec 2014 Location: The Angels
It definitely help with chassis flex in the rear. Whether or not that tranlstes to a better performing chassis in the real world, I couldnt say. But it does look cool.
07-19-2017, 01:38 PM | #5 |
I was bored and had some tube on hand. Stone dead simple and it was raining cats and dogs outside. I'm considering making a set to span the radio box spread as well. Just need to find some really, really long screws. KNK does have some 40mm ones but they're only in the mega bag and the price is a bit steep. I'm sure with some looking I can find what I need on the internet but I prefer buying from vendors that are RC specific even if the cost is a bit higher.
08-08-2017, 02:29 PM | #6 | |
| Re: Cheap and easy carbon strut tower braces Quote:
08-09-2017, 10:04 AM | #7 |
Rock Stacker Join Date: Jan 2012 Location: Vancouver
I used some cut up bits from the cage for mine after I did the "fast back" mod. The stock tie rod is another good piece to cut up for this kind of stuff after you upgrade to steel or titanium links. Good stuff!
Cheap and easy carbon strut tower braces - Similar Threads | ||||
Shock tower to shock tower carbon fiber chassis brace | Crazykev | Axial Yeti | 0 | 04-23-2016 12:48 AM |
Xtreme Racing Carbon Fiber front shock tower | Verboten77 | Axial Yeti | 2 | 03-10-2015 10:33 PM |
Snipers Fab Shop carbon chassis braces | sniper | Chassis and Suspension | 15 | 01-21-2014 05:25 PM |
easy pay on tower? | mudhunter | Chit Chat | 19 | 11-21-2009 05:12 PM |
