07-18-2017, 09:31 PM | #1 |
Newbie Join Date: Jul 2009 Location: upstate
| Confused on which SSD transmission to go with.
I have BMRC IFS kit installed on my wraith, and have the following setup. Gearing 13t/56t Castle SW3 1410 3800 kv castle motor lipo is 2s2p 7000 mah Running 1.9 tires and rims. What I am wanting to accomplish is the following. Have the ability to crawl as needed, and speed when I want it. Not sure if I want to use the 2 speed SSD transmission or the high ratio transmission. |
07-19-2017, 04:16 PM | #2 |
| Re: Confused on which SSD transmission to go with.
Wow, 75 views and not a single peep or info.... |
07-19-2017, 04:54 PM | #3 |
That is not a sensored setup, correct? I was kicking around the ssd 2 speed for my own wraith, but ultimately decided on the ssd hi ratio. I run a 3400kv sensored setup geared 19/54 on 4s. Mine is definitely not a good crawling setup, but it boogies in the sand! The 2 speed has the same hi gear as the hi ratio trans, and the extremely low 1st gear would probably allow crawling speeds on a non-sensored brushless setup. Check this out: R/C Calculations ...and my own one way conversation on wraith transmissions: Wraith trans choices for sand/dunes |
07-19-2017, 08:38 PM | #4 |
Thanks for the input.
07-19-2017, 11:38 PM | #5 |
RCC Addict Join Date: May 2013 Location: Forrestfield, Western Australia
Only suggestion I've got inlvolve leaving the trans & gearing exactly as is, Sell the 2s, SW3 & 1410 (unless it's the newer sensored version) Get 3s, (I'd suggest 2x 3500mah rather than a stinking great 7000 brick) & a sensored motor esc combo (Castle Mamba X, Holmes, Tekin, Hobbywing) |
07-20-2017, 01:02 PM | #6 |
Quarry Creeper Join Date: Feb 2014 Location: NNJ in the sticks
I'm with altd896. I have a SW3/4600kv setup in my RC10 and I was going to install it in the wraith but realized it would be a wasted effort. It's too much motor and the low speed response would be horrible. I ended up buying a castle crawler sensored 3600kv and a mamba X and couldn't be happier. Low speed crawling is great and it really gets up and moves. I have a full metal trans and am running bushings on the pinions. Just keep an eye on the bushings and replace when they get sloppy. |
07-21-2017, 04:30 PM | #7 |
ok, boy that just throws even more info into the mix. now trying to sell the setup... lol
Confused on which SSD transmission to go with. - Similar Threads | ||||
RC4WD Blazer body vs SSD Transmission | Fishbone.dk | Axial SCX-10 | 2 | 02-28-2019 08:46 AM |
SSD Scale Transmission for SCX10 | Rcdood | Axial SCX-10 | 121 | 12-27-2018 10:00 AM |
New SSD 2 Speed Transmission kit for Wraith | SSD | Axial Wraith | 43 | 12-28-2016 04:06 PM |
SSD-RC 2-speed transmission mini-review | tuanies | Axial SCX10 II | 4 | 10-28-2016 08:53 PM |
