Thread: Newbie Working on a New Build - LOTS of questions
Old 08-18-2017, 12:01 PM   #61
Default Re: Newbie Working on a New Build - LOTS of questions
Originally Posted by azTony View Post
It appears I put them on upside down... rookie!
I am also trying to get my wheels mounted on them but the bolt pattern is different. Not sure why Gear Head is so much different than the rest but I like the wheels. I need to get some drawings and find a machinist if Erik is not able to help me. Taking the steps forward to bullet proof the axle makes it a step backward to skimp at the wheels. I have no plans to change wheels, I like the quality of them
Having those knuckles as well, your top wing bolts need to be in the set of holes closest to the Chub and the lower wing in the set of holes closest to the wheel. That gives you the offset to connect to your Chubs properly.
Cheers
NWHavok is offline   Reply With Quote
Old 08-18-2017, 12:28 PM   #62
Well I set it up for non 8 degree when it is supposed to be 8 degree. Where do you find this type of information? Anyway it is corrected and the camber looks much better. The freaking drive train is tight. If I had wheels on here it would not roll without pushing. It is definitely German engineering "Good-n-Tight"!
azTony is offline   Reply With Quote
Old 08-18-2017, 12:51 PM   #63
Any information about Dlux parts I've received from Erik, he is on FB almost all morning answering questions and stuff. Down right best customer service I've ever encountered. And yes, good 'n tight is a great way to describe this drivetrain. You'll love it for a long time to come.
Also just my opinion, you should flip your shock mounts on your axles to lower the stance (center of gravity) just a little bit. You'll be happier with that in the long run. I've ran both and noticed a difference with them flipped.
Old 08-18-2017, 01:24 PM   #64
Getting pretty upset about now... try and pick what in my opinion is the best made wheels for RC and now I cannot even use them.
Time to go punish a little white ball with 500 dimples!!!
Old 08-18-2017, 03:13 PM   #65
Yup, it should be so tight it doesn't droop when holding it out straight.
He showed the difference in a video between the sloppy axials and his 8mm
https://youtu.be/JuewCC-2xvw
Hang up and Drive
mikemcE is offline   Reply With Quote
Old 08-18-2017, 03:52 PM   #66
I am talking once assembled It does not want to roll, you have to force it to roll
The tracking info shows my frame pieces I am waiting on will be here tomorrow so I am preparing. A little SRV to get me out of my sh*tty mood...
Old 08-18-2017, 06:18 PM   #67
Getting ready for frame pieces tomorrow and tranny tomorrow
Old 08-19-2017, 07:00 AM   #68
I need to find some place that sells some aluminum so I can make some spacers. The shocks need spacers to mount to the frame for one and there are more places that I will need spacers and then longer pieces for frame support in the front shock area. Where do others get your materials for this kind of stuff?
Old 08-19-2017, 09:22 AM   #69
Web Store
bilinvic is offline   Reply With Quote
Old 08-19-2017, 10:41 AM   #70
KNK works well, I also use SS tubing from ace (K&S)
Hang up and Drive
Old 08-19-2017, 12:28 PM   #71
Hang up and Drive
Ace? You talking about Ace Hardware?
Old 08-19-2017, 12:30 PM   #72
Now I can start...
What do you guys use to cut the frame?
Old 08-19-2017, 01:19 PM   #73
The place!
Most hobby shops and hardware stores sell K&S in a rack, brass and aluminum usually, my Ace also has SS tubing
Hang up and Drive
Old 08-19-2017, 06:43 PM   #74
I do not have arms yet so things are just kinda sitting in place...
Old 08-19-2017, 06:51 PM   #75
The place!
Hang up and Drive
I needed to space the top bar to clear the light bar, I moved it forward to keep from cutting the grill out. I cut 2 ea 5/16 spacers from 1/4" SS tube, that I got at Ace
Hang up and Drive
Old 08-19-2017, 07:08 PM   #76
My Ace Hardware is lame... They had very little of anything. I got some .25" aluminum bar that was solid. I could not find any tube
Old 08-21-2017, 12:59 PM   #77
I got my SS tube from amazon. Cheap enough and I didn't have to search the local lowes to find they don't have it.
Farabomb is offline   Reply With Quote
Old 08-21-2017, 06:45 PM   #78
Are the threads M3 x 0.05? Sorry, I feel like a 2 year old asking so many questions...
Old 08-21-2017, 07:31 PM   #79
Gotta be, that is the only thread I find for M3, now I have to find good tools. I am sure junk will break easy so I will steer clear of Harbor Freight
Old 08-21-2017, 11:40 PM   #80
Yep, standard M3x0.5mm
As an aside, pretty sure your C-hub screws are upside down, I'm sure on the ones I've got the pocket on the underside is just larger to take the hex of the nut.
Pivot balls are a great spacer also.
altd896 is offline   Reply With Quote
Newbie Working on a New Build - LOTS of questions - Similar Threads
Working on U4 Trophy type build, got a few questions first... 89redranger U4RC 7 03-21-2014 10:51 AM
Lots of newbie questions??? 4wd-n-archery Newbie General 16 08-28-2013 03:35 PM
Newbie Build + Questions tmwoodall Axial SCX-10 9 04-07-2013 03:31 PM
newbie SCX10 build questions Scott VA Newbie General 2 01-04-2010 04:58 PM
newbie lots of questions needs answers veewee25 General Crawlers 9 07-03-2007 07:33 PM
