08-22-2017, 05:58 AM | #81 |
Pebble Pounder Join Date: Jun 2017 Location: United States
| Re: Newbie Working on a New Build - LOTS of questions
Thanks, I thought something looked strange |
08-23-2017, 04:34 PM | #82 |
Got my gear and the tranny is together and motor mounted! The top shaft had zero play in it but I put a bearing behind the pin any way, there was room. Are you supposed to grease these gears? How tight should the mesh be between them? Last edited by azTony; 08-23-2017 at 04:50 PM. |
08-23-2017, 04:42 PM | #83 |
Always a light coat of quality grease, moly or Red and tacky work well. They should spin smooth w/I binding Hang up and Drive |
08-23-2017, 06:31 PM | #84 |
RCC Addict Join Date: May 2013 Location: Forrestfield, Western Australia
Grease trans internal gears, the case is sealed enough to keep most grit out Don't grease spur/pinion, the spur cover doesn't seal that well & dirt will get in. |
08-23-2017, 07:29 PM | #85 |
grrrr... sorry but mikemcE replied and said a light coat so I did. I guess I have work to remove the mess! Where does everyone get those wrenches to tighten/loosen the spur gear nut? Those are compact and handy compared to what I am using |
08-23-2017, 07:44 PM | #86 |
Sorry, slipper and pinion are always dry. Pinion and spur I feel the mesh, and can hear it if I set it right . Hang up and Drive |
08-24-2017, 12:45 AM | #87 |
Forgot to mention a bit of graphite powder works great on metal pinon/spur
08-24-2017, 12:17 PM | #88 |
Quarry Creeper Join Date: Feb 2014 Location: NNJ in the sticks
In a pinch pencil lead can work too. You just gave me an excuse to go buy some graphite powder at the LHS though.
08-24-2017, 08:52 PM | #89 |
So I need some ideas. I have a Stiffy Kit for my Wraith and when I bolt up the frame (new out of the bag) the holes were pretty far off. I played with it for well over an hour trying to get the 2 sides on. Granted you have to redial the top two holes in the frame just above the windshield on both sides and that was done. I tried several different approaches to put one screw in first and then different sequences after that and in the end I always had one hole that I had to pull and hold to where I thought I was going to break the frame while I was waiting for my wife to get the screw in because it took both hands to hold this thing. In the end I got them all in and I was covered with sweat. Now I will be taking this thing apart and putting it back together many many many times in the future and I do NOT want to do this every time. Any tricks to get the frame to hold a particular shape??? |
08-24-2017, 09:52 PM | #90 |
You have far too much faith in our physic abilities.......pictures? Not following how it doesn't fit & what needs bending |
08-25-2017, 09:05 AM | #91 |
Sorry, it is together now and I do not want to take that bitch apart again! I do have pics from when it was apart. I will post them up when I get home.
08-25-2017, 02:21 PM | #92 |
Sorry this is all I got. Ny suggestions?
08-25-2017, 08:05 PM | #93 |
I wanna be Dave Join Date: Sep 2012 Location: Victoria, BC
If I recall correctly, mine was similar too....I've never had a reason to take it apart so it's a non-issue for me.
08-26-2017, 05:16 PM | #94 |
I was thinking about hitting it with my heat gun while it is together to see if that would help. Anybody have experience with that?
08-27-2017, 11:53 AM | #95 |
I'd think it would just spring back to the original position after it cooled. When it's all assembled does it really tweak it that much? It looks to be only a little off center to center. It may not be an issue after everything is bolted together.
09-04-2017, 06:55 PM | #96 |
Too... freaking... tall... I don't think the arms are installed correct either |
09-05-2017, 05:05 PM | #97 |
Your front looks like mine Height wise Hang up and Drive |
09-05-2017, 05:10 PM | #98 |
From what I see the lower frame rail that bolts to the bumper, mine "looks" about 1" taller in the front. My other wraith the shocks are much more forgiving and the ones I have on are stiff. The shock oil I used was 30 and I even put all the parts that will be on the rig on it and it never lowered. Just seems way too stiff and again, the arms do not look right. The front uppers touch the servo
09-05-2017, 05:10 PM | #99 |
Here Hang up and Drive |
09-05-2017, 05:12 PM | #100 |
Thanks
Newbie Working on a New Build - LOTS of questions - Similar Threads | ||||
Working on U4 Trophy type build, got a few questions first... | 89redranger | U4RC | 7 | 03-21-2014 10:51 AM |
Lots of newbie questions??? | 4wd-n-archery | Newbie General | 16 | 08-28-2013 03:35 PM |
Newbie Build + Questions | tmwoodall | Axial SCX-10 | 9 | 04-07-2013 03:31 PM |
newbie SCX10 build questions | Scott VA | Newbie General | 2 | 01-04-2010 04:58 PM |
newbie lots of questions needs answers | veewee25 | General Crawlers | 9 | 07-03-2007 07:33 PM |
