08-27-2017, 08:23 AM | #1 |
Quarry Creeper Join Date: Feb 2014 Location: NNJ in the sticks
| Machining question
So I received my 13mm endmill to attempt to bore out the bearing retainer in the axle to accept a 13mm bearing. I unfortunately don't have easy access to a milling machine so I'm attempting to do it with a drill press and a vice. I want to make sure it's perfectly centered in the bore. Since the endmill flatcuts it won't self center like a normal drill and a pilot hole. My thought was to get a 13mm drill that will hopefully center it, lock down the vice then use the endmill? I have extra axles but with Axial plastic parts having supply issues I don't want to destroy too many. |
08-27-2017, 10:44 AM | #2 |
| Re: Machining question
Maybe center it up with a 5mm bit run through an installed bearing, then once your housing is secured, pop out the bearing (or only install the outer bearing and leave it in while you cut the inner seat) and go for it with the 13mm? That's what I'd do anyway.
08-27-2017, 11:29 AM | #3 |
Didn't think to use a bit run through installed bearings. Use that to locate everything then lock it all down.
Machining question - Similar Threads | ||||
Machining question | BigSki | Tools, and Procedures | 29 | 04-02-2017 08:05 AM |
General gear tooth machining question...from a nube... | ChattyMatty | Newbie General | 2 | 01-11-2010 06:51 AM |
Making custom rims/Machining question | Redfinger | Tires and Wheels | 19 | 11-24-2009 12:55 AM |
