09-14-2017, 04:58 PM | #1 |
Rock Crawler Join Date: Apr 2015 Location: Paola, ks
| Vanquish VVD binding
This short VVD for my wraith is binding when I tighten up the knuckle. If I loosen up one screw about 2 turns the knuckle loosens up and the axle spins freely. The bind in the axle rotating is only in one spot as if the shaft was bent. I checked the shaft as best as I could on a very flat surface and saw no noticeable wobble. The knuckle will not turn freely if both screws are tight. Now the weird part is that when I put the stock shaft back in, everything is fine. Even weirder is that the VVD rotates and wiggled very freely when outside of the axle housing. The axle housing does have beef tubes in it. I was trying to install these in my existing axle. I bought them used and will be disappointed it they are bad. I have had a strong of bad parts bought used here lately. Unfortunately I bought them weeks ago and am just now getting to use the parts. Also the locker was a fancy set screw 2 piece vanquish locker that had all the screws sheared off. So it's trash too. Vanquish no longer makes them so I can not get parts for it. Sent from my SM-N920V using Tapatalk |
09-14-2017, 06:20 PM | #2 |
Rock Crawler Join Date: May 2013 Location: Dallas
| Re: Vanquish VVD binding
Are the knuckle screws hitting the vvd?
09-14-2017, 07:53 PM | #3 |
Quarry Creeper Join Date: Feb 2015 Location: Norway
I have had the same problem, the problem i had was that the tang was abit to long, and woud cause binding. You coud try and grind down the end abit. |
09-15-2017, 01:48 PM | #4 |
| Re: Vanquish VVD binding |
09-15-2017, 01:49 PM | #5 |
| Re: Vanquish VVD binding I will be trying this. Easy to do and will harm nothing if you are wrong. It must me just a little tiny amount. Im going to try it now. |
09-18-2017, 06:41 AM | #6 | |
| Re: Vanquish VVD binding Quote:
Sent from my SM-N920V using Tapatalk | |
09-19-2017, 11:10 AM | #7 |
Quarry Creeper Join Date: Feb 2014 Location: NNJ in the sticks
Stock lockers? I had an issue with binding when I had the HR set screw lockers. It was tough getting them exactly even when tightening them.
Vanquish VVD binding - Similar Threads | ||||
Vanquish vvd | goingvertical | Axial Wraith | 28 | 05-23-2017 05:49 AM |
Vanquish VVD issue | BlownChevelle | Axial RR10 Bomber | 4 | 11-13-2016 01:34 PM |
Vanquish vvd rebuilds | rc crawler boy | Axial Wraith | 16 | 06-28-2013 10:49 PM |
Vanquish VVD | GravelDuster | Axial Wraith | 3 | 08-24-2012 03:09 PM |
