10-13-2017, 12:09 PM | #1 |
Rock Crawler Join Date: Apr 2015 Location: Paola, ks
| Trans output shafts?
So I tried to take apart my transmission to install a dig unit and ended up drilling out the front mip cross pin to get the trans apart. This ruined the mip drive coupler as well as the front ouput. The transmission is a new hot racing unit with steel gears. What is my best option going forward? I'm up for anything from the cheeseburger transmission to anything that will prevent this from happening. This stinks since the build only has a few hours runtime. I am running 38/43 axle gears. I was not able to find a hot racing direct replacement output shaft. Thanks in advance. Sent from my SM-N920V using Tapatalk |
10-13-2017, 01:02 PM | #2 | |
| Re: Trans output shafts? Quote:
10-13-2017, 01:06 PM | #3 |
| Re: Trans output shafts? It was a VF DIG unit. Looks very nice, but when I realized that the output shafts were aluminum, I abandoned ship. However, the damage was already done to the transmission. Want to buy it? lol. The DIG unit? I have been told they are really good. It is the same length as the stock HR trans.
10-13-2017, 07:19 PM | #4 |
Hot racing makes a one piece lower gear/ outputs.... I have 2 of them and they will fit into the hot racing trans case...durable and low cost... http://m.ebay.com/itm/Hot-Racing-Ste...056?nav=SEARCH Last edited by allanon1965; 10-13-2017 at 07:21 PM. |
10-15-2017, 07:01 AM | #5 |
Quarry Creeper Join Date: Feb 2014 Location: NNJ in the sticks
I run the robinson racing one piece and it's a beefy SOB. I've had good and bad luck with hot racing but the piece linked above doesn't look horrible at all. Looks substantially lighter than the robinson one and might be a benefit in a brushed rig.
10-15-2017, 07:37 AM | #6 |
Build up a bombproof with SuperShafty parts. Hang up and Drive |
10-16-2017, 09:30 AM | #7 |
Super shaft is out of parts right now or I would Sent from my SM-N920V using Tapatalk |
Trans output shafts? - Similar Threads | ||||
Anyone have Crawler Innovations output shafts on their SCX10 trans? Advice and help!! | ZippoMan | Axial SCX-10 | 21 | 11-30-2013 08:06 PM |
Dig Options For Pin Through/WB8 Style Trans Output Shafts? | NFA Fabrication | Axial SCX-10 | 1 | 11-25-2011 05:56 AM |
Axial Trans output shafts | Gozer | Axial AX-10 Scorpion | 12 | 04-06-2009 01:02 PM |
