10-22-2017, 02:31 PM | #1 |
Rock Stacker Join Date: Mar 2016 Location: Nashville
| VP Currie Rockjock Axle Servo Mount
Will the one piece servo mounts like this work on Wraith Rockjocks: https://www.ebay.com/itm/Vanquish-Al...4AAOSwH35ZpH1v OR does it have to be this one: https://www.amainhobbies.com/vanquis...s06701/p248485 I'd love to use the one piece ones, but haven't been able to find a definitive answer anywhere. Thanks! |
10-22-2017, 05:57 PM | #2 |
RCC Addict Join Date: Nov 2016 Location: 1972 born Christian, Chinese.
| Re: VP Currie Rockjock Axle Servo Mount
OR does it have to be this one: https://www.amainhobbies.com/vanquis...s06701/p248485 I'd love to use the one piece ones, but haven't been able to find a definitive answer anywhere. Thanks![/QUOTE] Yup, I think you need one if you want to install the servo on your front axle. ( Someone correct me if I were wrong ) Thank you |
10-23-2017, 11:22 PM | #3 |
RCC Addict Join Date: May 2013 Location: Forrestfield, Western Australia
The second one you linked is specific for the SCX10 Rockjock & will not fit the Wraith Currie truss. It's my understanding the Wraith Rockjock takes a a normal servo mounting plate on the top of the truss so the 1 piece https://www.ebay.com/itm/Vanquish-Al...4AAOSwH35ZpH1v should work just fine. If you own the axle housing already & can lay hands on the original Axial servo plate check the holes line up with the truss, if so the VP 1 piece mount will definitely work. |
10-24-2017, 04:37 AM | #4 |
Rock Stacker Join Date: Apr 2012 Location: zeeland
The VP one piece ar60 servo mount works on rockjocks. Sent from my iPad using Tapatalk |
VP Currie Rockjock Axle Servo Mount - Similar Threads | ||||
Currie rockjock scx10 rear axle | wings1024 | Axial RR10 Bomber | 5 | 02-14-2017 05:31 PM |
Vanquish Currie RockJock Axle | fatroofus | Newbie General | 7 | 01-16-2016 11:31 AM |
VP Currie on axle servo mount??? | Tech | Axial Wraith | 4 | 12-13-2015 01:38 AM |
Problem with front VP Currie Rockjock axle | kuyawil | Axial SCX-10 | 2 | 02-20-2015 07:13 AM |
Currie Rockjock Axle Owners ? | cmbscx10 | Axial SCX-10 | 9 | 08-29-2014 02:30 PM |
