Thread: Cheez Berger transmission on Wraith
Old 10-25-2017, 05:56 PM   #1
Default Cheez Berger transmission on Wraith
Found these new KYX brand ( Very small pumpkin size front axle ) in taobao; https://item.taobao.com/item.htm?spm...cket=14#detail
The KYX Wraith front axles use the same AR44's steel bevel gear set, same ratio as Original Axial 38T/8T.
Currently I am using under gear on the rear, I am thinking to use this KYX front axle with CheezBerger trans. So my question is, Can I Over drive the front 38T/8T bevel gear a bit? At least and need to be a bit faster than the rear wheels spin. Would this possible?
Thank you guys for helping me here
Teng is offline   Reply With Quote
Old 10-25-2017, 07:05 PM   #2
Default Re: Cheez Berger transmission on Wraith
Would you look at that... deadloc sells them anodized black for $255 a set. Same damned axles.
The gearing difference is huge, you'd be better off getting the matching rear axle and flipping it upside down to use the cheezberger.
WHITE-TRASH is offline   Reply With Quote
Old 10-26-2017, 12:49 AM   #3
LOL, I've almost forgot in US you got deadloc selling these KYX's products, Unfortunately Their selling is way too high. If you buy these axles in China only cost you USD$70.00 for the complete axles.
I thank you for your advice here which it I was agreed to your point. make sense everything.
Last but not least; I like you as you're Durability Tester
Old 10-26-2017, 01:48 AM   #4
Deadloc came from nowhere and showed up with a large variety neat parts. It is not surprising that they are simply a rebranding company but I hadn't realized just how high their markup must be. I'll look around that site later and see what kind of crazy deals I find.
Is that $70 for both front & rear complete axles?
I have broken pikes of parts and spent a bigger pile of money buying parts. Now I get to reat things as a hobby to help others. I enjoy it!
Old 10-26-2017, 02:58 AM   #5
No, USD$70 Either for front or rear. They are same price, USD$ each complete axles
We rc fans always down to rabbi hole, just spending a lot of money. Good to know you're helping others and enjoy it
Old 10-26-2017, 06:41 AM   #6
Yashua
CREEPERBOB's Avatar
And where are they available?.
CREEPERBOB is offline   Reply With Quote
Old 10-26-2017, 06:49 AM   #7
Hi, if you know Chinese, you may order from Taobao (( https://item.taobao.com/item.htm?spm...cket=14#detail ) They do ship to USA though.
or you can order in rcmart Hong Kong for
USD$82.90 free shipping
Sorry I forgot to provide you the link, here you go: http://www.rcmart.com/assembled-alum...0-p-75420.html
Old 10-26-2017, 06:56 AM   #8
Yashua
CREEPERBOB's Avatar
Sorry I forgot to provide you the link, here you go: for AXIAL WRAITH RR10 #XS-AW-1XS (FREE SHIP), ,(XS-AW-1XS) by Xtra Speed Assembled Aluminum CNC & Alloy Front Axle
Can't find them at RC Mart.
Old 10-26-2017, 07:04 AM   #9
Yashua
CREEPERBOB's Avatar
Thanks
Old 10-26-2017, 07:04 AM   #10
Please try the above link again. They are rebranding under Xtra Speed
Old 10-26-2017, 07:05 AM   #11
You're welcome
Old 10-26-2017, 09:49 AM   #12
Moderator
JatoTheRipper's Avatar
Nice looking axles and a decent price if they hold up.
But this style of axle pumpkin needs to die. It's fugly.
Old 10-26-2017, 02:31 PM   #13
If you don't buy those axles because they're not aesthetically pleasing I don't think anyone else cares. That shape slides over rocks and is simple to make from flat plate with a plasma and a press brake. That's where the design came from.
Old 10-26-2017, 06:11 PM   #14
Moderator
If you buy these nobody cares.
Old 10-26-2017, 06:35 PM   #15
Thank you Senior Jato uploading such a beautiful picture. I really appreciated
Old 10-26-2017, 08:20 PM   #16
I've got something in the works that is so much better than chicom cast alumargerine housings with pressed tin axle shafts.
I'd actually looked into using these housings but just the center section simply because the ring gear is flip able so the high pinion is retained while the direction of the rotation is reversed. Buuuut then ssd came out with their new plastic version so no heavy chinesium pumpkin for my axles.
Old 10-27-2017, 07:01 AM   #17
Moderator
Tell us more.
I don't mind these housings that much and I know they have a purpose (more clearance and easier to slide over rocks) and they look this way for a reason (cheap to fabricate), but I still prefer pumpkins. Because scale nerd!
Old 10-27-2017, 07:48 AM   #18
More information will come out soon enough.
They are all "scale" as can be. But because scale nerd nothing has to make any sense so there is that.
Old 11-03-2017, 04:13 PM   #19
The look of a custom fabbed ford 9”
Hang up and Drive
mikemcE is offline   Reply With Quote
Cheez Berger transmission on Wraith - Similar Threads
RC CHEEZ-IT Challange! twissted Formula Offroad 0 10-22-2014 10:00 PM
Tbone Berger Ktbone EnRoute Berg 3 02-21-2010 08:03 AM
newbie berger simone.west EnRoute Berg 2 05-19-2009 01:56 PM
