Thread: Newbie Working on a New Build - LOTS of questions
Old 08-02-2017, 06:04 AM   #1
Default Newbie Working on a New Build - LOTS of questions
Well I bought a used one and was looking at things to do to it and thought I am changing most of it so why not build one. My wife is already hating me...
I have a DMG Stiffy ordered, talked a little about the motor and ESC and figured I should first get the chassis and axles together then get the electronics in place.
The next big purchase will be axles and I am torn because I see there are a lot of you out there with the offset axles and a lot with the centered axles. I am looking at the Currie RockJock 70 axles and wanted to hear real life experience opinions on centered vs offset axles. In my full size 4X4 I prefer a more inline geometry for strength but then again I have a 6,000 lb Landcruiser with 37's spinning.
Let's hear from your experiences on the experts in this hobbie, centered or offset? Pros and Cons please
azTony is offline   Reply With Quote
Old 08-02-2017, 06:26 AM   #2
Centered out back.
Look into the SSD diamonds..... great value and performance.
With my motor and gearing this truck can be a monster, full throttle will pull a full even wheelie, when full traction is there. The centered rear eliminated most of my torque twist.
This in NOT a wheelie truck, normally slow in the rocks, but I can jump it out of a deep spot if needed. I run rip rap primarily so this helps me.
Stock gearing (HD upgrade) incision locker . I always add the SSD delrin pinion protector
I went this way as it was the cheapest accessory wise. Comes with the HD axles now, no lockouts needed. All shock mounts are the same so what you have will work.
Hang up and Drive
mikemcE is offline   Reply With Quote
Old 08-02-2017, 11:46 AM   #3
Default Re: Newbie Working on a New Build - LOTS of questions
Are these He ones to have to flip the gears because hey are opposite? How do they hold up as far as bending? I do not see much as far as support at the center pumpkin
Old 08-02-2017, 11:54 AM   #4
Hold stock axial gears , I put them in the way the old came out. These are solid metal, they are shiny on the bottom of both currently. As I crawl I don't run a U4 truss setup, I've yet to bend an axle or even flatten a bearing . I run 3 of these, 2 in the Wraith and a wide on my Yeti . Bulletproof , 3s and Holmes or Tekin power , I don't baby anything
Hang up and Drive
Old 08-02-2017, 12:14 PM   #5
Good answer! I was looking at the VP knuckles and they have a high steer type of approach and I did not see that on the SSD, can the knuckles from VP mount on the SSD's?
Old 08-02-2017, 12:22 PM   #6
Yes, I used a complete VP kit in orange.
Hang up and Drive
Old 08-02-2017, 01:14 PM   #7
Nice! Now I will work on the gearing so I can order everything at once. Anyone know of any of the shops have sales or will have a sale relatively soon? I need to order my TA's too
Old 08-02-2017, 04:33 PM   #8
I like those knuckle weights on the steering. Kinda wish they worked with the scale vanquish knuckles I have.
Farabomb is offline   Reply With Quote
Old 08-02-2017, 04:59 PM   #9
Those are from RC Bros
Hang up and Drive
Old 08-02-2017, 05:57 PM   #10
I saw they had those. The scale knuckles don't have the adjustable ackerman plates so I'm S.O.L. I might be able to fab a mount that might work but it would ruin the scale look and I'm not sure how strong it would be. I really like the idea of adding weight without adding rotating mass. Having wheel weights on my front rims is probably adding to my issues with the pinion contacting the inside of the axle. Those hexes are quite nice as well.
Old 08-04-2017, 09:12 AM   #11
But those are not SORRCA legal... If you play scale I mean..
Sent from my Nexus 6P using Tapatalk
D440 is offline   Reply With Quote
Old 08-04-2017, 09:24 AM   #12
Totally true, I don't so I can run them.
Hang up and Drive
Old 08-04-2017, 09:25 AM   #13
Moderator
JatoTheRipper's Avatar
SORRCA. They're the ROAR of the crawling world, but that's just my 2 cents.
The centered rear looks great. Now I wish somebody would do the same for the front axle.
Old 08-04-2017, 10:29 AM   #14
Are there axles (internal axle shafts) that are different lengths for whatever reason? I am trying to get a parts list together with numbers so I can try and find a place to buy everything from in hopes of saving some coin. This is going to be an expensive build
Old 08-04-2017, 10:59 AM   #15
Yes , with normal pumpkin off to one side one axle is short, one long. Centered pumpkin means axles are same length
Hang up and Drive
Old 08-07-2017, 04:13 PM   #16
Originally Posted by mikemcE View Post
Centered out back.
Hang up and Drive
Pardon my ignorance but what do you mean "no lockouts needed"? I did not see where it comes with the HD axles (SSD00081), I was going to buy them separately.
Old 08-07-2017, 04:58 PM   #17
"Lockouts are on the outside ends on stock AR60 axles, they hold the end bearings, not needed with SSD
Axles
I know they are listed separately , but I have 3 SSD diamonds. 1 front, not applicable. I have a wide on my Yeti, when I ordered it I had a set of HDs on hand, I still have them as a spare. The way to see is if the axles come with the slotted hexes, mine did . You can see them in the first picture, small bag up front.
The only complaint I had read was the stock axles bending, and the upgrade solved it.
Hang up and Drive
Old 08-08-2017, 04:55 PM   #18
I talked with Chris at SSD and he said the only one that comes with the HD is the Yeti wide axle housing
Old 08-08-2017, 04:57 PM   #19
OK makes sense as I did get that for the yeti, regular on the wraith
Hang up and Drive
Old 08-08-2017, 05:00 PM   #20
So is incision the best or cheapest? Just asking because at https://www.amainhobbies.com/incisio...c00001/p487847 they have bad reviews about sloppy fit
Newbie Working on a New Build - LOTS of questions - Similar Threads
Working on U4 Trophy type build, got a few questions first... 89redranger U4RC 7 03-21-2014 10:51 AM
Lots of newbie questions??? 4wd-n-archery Newbie General 16 08-28-2013 03:35 PM
Newbie Build + Questions tmwoodall Axial SCX-10 9 04-07-2013 03:31 PM
newbie SCX10 build questions Scott VA Newbie General 2 01-04-2010 04:58 PM
newbie lots of questions needs answers veewee25 General Crawlers 9 07-03-2007 07:33 PM
