11-19-2017, 05:49 PM | #1 |
Rock Stacker Join Date: Aug 2016 Location: Maine
| SD Knuckles and chubs
What Is the difference between the d60 and the pro? Maybe a better questions what is the difference between the d60 axles and the ar60?
11-19-2017, 07:09 PM | #2 |
RCC Addict Join Date: May 2013 Location: Forrestfield, Western Australia
| Re: SD Knuckles and chubs
Pro knuckle is high steer, D60 knuckle is not.
11-20-2017, 03:43 AM | #3 |
RCC Addict Join Date: Oct 2014 Location: UK
Seems the question has a few things mixed together so I will try and answer... The SSD Pro knuckles for Wraith are a scale 1:1 aftermarket style knuckle that is high steer: They dont have longer steering arms than stock and they dont need a shorter steerling link. They are just higher than stock. HD D60 knuckles are similar to stock Bomber/SMT10 knuckles but with 13mm bearings in the front: They also dont need any different steering links. The HD D60 rear axle: The D60 rear is different to the stock rear AR60 axle in a many ways: 1) Centered diff housing 2) no separate rear lockouts 3) larger (13mm) pinion shaft bearings 4) thicker axle tubes 5) looks much more scale Last edited by SSD; 11-20-2017 at 04:12 AM. |
11-20-2017, 07:15 AM | #4 | |
| Re: SD Knuckles and chubs Quote:
11-20-2017, 08:37 AM | #5 |
All of our knuckles fit on stock C hubs.
11-20-2017, 09:13 AM | #6 |
| Re: SD Knuckles and chubs |
11-20-2017, 03:43 PM | #7 |
11-20-2017, 04:30 PM | #8 |
Apologies for incorrect info, without both pairs in hand to compare I have misinterpreted the notes on the Pro product page referring to parts req'd for the RR10. Had not realised there was a HD D60 knuckle with the big outer bearing, I llike a lot, would like even more if they we're high steer as well. Last edited by altd896; 11-20-2017 at 04:33 PM. |
11-21-2017, 02:25 AM | #9 |
| Re: SD Knuckles and chubs This was answered in another thread recently: Axial Wraith Plastic Axle Options The front axle drawing was done at the same time as the rear but the numbers dont justify it at the moment. |
11-21-2017, 08:41 AM | #10 |
Can the pinnion be fliped on that d60 axle
11-21-2017, 09:46 AM | #11 |
SD Knuckles and chubs - Similar Threads | ||||
Knuckles and chubs | CHROMECRAWLER | Axial SCX-10 | 10 | 12-28-2013 03:36 PM |
Knuckles and Chubs | elvis3714 | Axial Wraith | 6 | 11-12-2011 05:14 PM |
