12-12-2017, 11:28 AM | #1 |
| Wraith is going on a DIET!
I had my Wraith built up with all sorts of scaler items, aluminum body panels, LED light bar up front, rear light bar, fuel cell, hi-lift jack, fire extinguishers, etc. Since I'm building a true 1.9 scale Truggy, I figured I'd get the Wraith back to fighting weight and bag a lot of the non-essentials. So far, I snubbed the front nose, did a type of FastBack mod, blacked the interior floor pan and patched up all the old LED and accessory lighting holes in it with aluminum, I also fabbed up an aluminum dash since the old lexan one was mangled. Waiting on my BGR Fab front and rear shock towers. In the meantime, I'm re-positioning my electronics. Receiver used to live up front, and ESC road shotgun with passenger seat delete. Using an RC4WD fuel cell to position the receiver out back, moving the ESC up front where the receiver used to be. My PullerPro 3500kv and BLE are due here Wednesday. Can't wait to see the difference with the increased brushless power and weight loss. (Was running a 13T CrawlMaster and BR-XL.) I'm also going back to a lexan body versus all the aluminum panels. Have an un-painted ProLine Wrangler Rubicon body laying around that should do nicely. |
12-13-2017, 02:24 PM | #2 |
Newbie Join Date: Apr 2017 Location: Rochester Hills
| Re: Wraith is going on a DIET!
That dash looks so clean!
12-13-2017, 02:37 PM | #3 |
Nice! I always seem to build heavy rigs but I've been looking at a few areas for weight savings on my Wraith and I happened to pull one of the seats out and man are they heavy, they seem to be solid plastic and pretty thick. Anyway I picked up a set of the Gmade Gom seats which are definitely lighter and a similar size. I may just get started on that tonight and I can post up a pic and some weights of each if you'd like. |
12-13-2017, 07:40 PM | #4 |
| Re: Wraith is going on a DIET! |
12-13-2017, 07:43 PM | #5 | |
| Re: Wraith is going on a DIET! Quote:
12-13-2017, 08:46 PM | #6 | |
Okay I finally weighed the Gom seats and they aren't the huge weight savings I had hoped for. The stock Axial seat is 1.9 oz, 3.8 oz for the set The Gmade Gom seat is 1.4 oz, and 2.8 oz for both So 1 oz of weight savings, oh well at least it was something side by side, the Gom seats are 3/8" taller and 11/16" wider at the bolster Also the side bolster sticks out farther, just a bit past the cage. The interior panel could likely be trimmed to allow the seat to move inwards. Maybe with some heat these can be bent inwards as well. RPP has the seats for sale though I imagine there are better options out there, maybe a 3D printed one since it should have a honeycomb inner structure. Last edited by HumboldtEF; 12-13-2017 at 08:53 PM. | |
12-14-2017, 08:29 AM | #7 |
I like the look of the GOM seats! Are you going to go ahead and use them then? I agree - I think you could probably use some heat to mold them to fit. That way you're not hacking on them. Thanks for the info!
12-14-2017, 11:42 AM | #8 |
| Re: Wraith is going on a DIET! Yeah I will be using them after all. I'm not sure I'll be putting my driver back though, Homer might just be too fat.
12-15-2017, 07:26 AM | #9 | |
I've been looking at different driver options. I did order a Spawn lexan Interior for weight savings, but it's back ordered in to January. I'm still going to go ahead with this interior since I have another Wraith chassis that I can build up over time for my daughter. I found these drivers on EBAY and they look legit, if not a bit pricey. https://www.ebay.com/itm/1-10-scale-....c100290.m3507 If you scroll through the pics, he's even got one mounted in a Wraith and the scale looks great! Last edited by mewalsh100; 12-15-2017 at 07:27 AM. Reason: adding info | |
12-15-2017, 08:36 AM | #10 |
I’m lovin the dash also. How is it mounted? I may have to bend one up! Hang up and Drive |
12-15-2017, 09:00 AM | #11 | |
Looking at doing a whole floor pan next. Due to the complexity of the bends, I think it will need to be in 3 pieces, Driver side, Passenger side and Trans tunnel. Then I'll either use pop rivets, some small stainless hardware, or ideally, spot weld it. | |
12-15-2017, 09:01 AM | #12 |
So I just ordered one of the drivers figures from the Ebay link above. You can specify driver (they're NASCAR), seat color (Black or Gray) and Harness color. Pretty cool.
12-19-2017, 06:17 PM | #13 |
Got the Proline dash decals stuck on the aluminum dash. Body is taped up and being painted tonight! |
12-21-2017, 12:03 PM | #14 |
Not exactly the color I was going for, but I guess it'll do. I bought a Fluorescent Powder blue, not realizing it had to be backed with a solid of the same color. I ended up backing it with a darker can of blue I had laying around. at $10 a tiny can, you'd think there was actual gold in the paint! |
12-21-2017, 12:17 PM | #15 |
Yeah, fluorescent colors seem to turn out best when backed with plain ol' white. I hate finding that stuff out the hard way!
12-21-2017, 12:24 PM | #16 |
| Re: Wraith is going on a DIET! Yeah. I should've known better. I did a FLO green body a few years back. I ended up going back to buy the solid green to back it. And then white behind that. Oh well, it turned out ok and it's just going to get thrashed up any way! |
12-21-2017, 05:14 PM | #17 |
I wanna be Dave Join Date: Apr 2015 Location: Roseville, Ca
When are your BGR shock towers arriving? I ordered the rear from amain today, but front is out of stock. I should have the rear here tomorrow. But the reason I ask is I've seen a few people mention about the front not having the 2 side braces, and being wobbly so I was going to see if you noticed that yet.
12-21-2017, 07:05 PM | #18 | |
12-21-2017, 07:35 PM | #19 |
Ya, I came across this thread yesterday. Stiffening up front end after bgr tower install Edit: When I get my front tower ordered, Im thinking about trying those 27mm standoffs from rc4wd or reuse some plastic from the cage. I can't imagine it being that bad, but definitely keep us posted. Last edited by 84yoda; 12-21-2017 at 07:38 PM. |
12-22-2017, 05:14 AM | #20 | |
Wraith is going on a DIET! - Similar Threads | ||||
CR-01 needs a diet | mulepic | Tamiya CR-01 | 5 | 07-06-2009 08:47 AM |
betty's on a diet | colonelangus | Chit Chat | 8 | 01-28-2008 03:25 PM |
do you think she needs to go on a diet | Will | Chit Chat | 8 | 07-30-2005 04:04 PM |
