01-04-2018, 09:19 AM | #1 |
Newbie Join Date: Dec 2012 Location: oreana
| big motor
hello, first time posting. building a wraith and i want to put a castle 2650 motor in it but it is to long. i do not want to grind away any of the link mounts material away. any suggestions or am i just out of luck. i have that motor in my yeti and it barely fits. thank you in advance for any help kz903
01-04-2018, 10:33 AM | #2 |
| Re: big motor
You will need to grind the corner off the mount. No need for that motor in a wraith, as it’s not sensored Hang up and Drive |
01-04-2018, 12:25 PM | #3 |
| Re: big motor
Yeah I'm not sure it needs a motor this big either, you'll find a 540 or 550 brushless (sensored) motor should provide more than enough wheelspeed and power to overwhelm a Wraith. If you like Castle I'd look into their new Slate motors made just for crawlers What is your goal with this motor anyway? |
01-04-2018, 04:45 PM | #4 |
| Re: big motor
hello, thanks for replies. castle offers the 2650 mamba monster x in a sensored package 010 0145 04. that is what i have in my yeti. plenty of grunt and power ,runs cool on a 3 cell lipo, plenty of run time. been looking into putting in a yeti trans or a bomber trans. i just like this motor and monster esc. i have it in my slash 4x4 plenty of giddy up. just like this motor, just trying to figure how to use stock wraith stuff first. thanks kz903
01-04-2018, 05:00 PM | #5 |
| Re: big motor
The gear ratio on the Yeti/Bomber tranny is a little taller. Shouldn’t be much of a problem though with the Wraith tranny. I used some longer m3 bolts and a couple of m3 nuts and raised the motor side of my Wraith tranny a little bit to clear a motor before. I don’t run it any more because it really wasn’t worth it when I can do the same on a 550 Traxxas.
01-04-2018, 05:09 PM | #6 |
| Re: big motor
Ah it is a sensored motor after all, thats good though it still might not have the low speed control as good as the crawler specific motors which will also rip at full throttle BTW. have a look at their rock crawler combos with the mamba X Holmes Hobbies also makes some awesome brushless crawler motors too I had a Tekin 3100kv roc 412 in my wraith for a while but it was a bit much so I put a 2100 kv Holmes puller pro in. I felt that the Holmes motor or atleast the KV rating was a bit more suited for this rig, though I do have a 2 speed as well. |
01-04-2018, 06:58 PM | #7 |
| Re: big motor
hello, thanks for the replies. looking at some of new castle slate systems. i might inquire about their outrunner motors. love that screaming sound it makes ,all want is plenty of power cause my wraith is pulling a little extra weight ,bgr aluminum, hi-lux body. so again thanks for input. kz903
01-04-2018, 08:43 PM | #8 |
| Re: big motor
Looking for Power or speed ? The 2650 sensored will be a beast, unless you can get it low enough to keep it on the ground., I’m running a PP3500 and it fits perfect, will give much more speed than my truck wants Hang up and Drive |
big motor - Similar Threads | ||||
how big is the titan 775 motor | 12voltfun | Traxxas Crawlers | 2 | 04-05-2009 07:00 PM |
Small motor / Big performance | motorman1600 | Electronics | 11 | 11-07-2008 02:18 PM |
