Thread: Wraith Spawn run time
Old 01-16-2018, 08:02 AM   #1
Question Wraith Spawn run time
I'm planning on getting a Wraith Spawn kit soon and I'll be running a Hobbywing 1080 esc & 45t brushed motor.
I'll just be using the rig for trailing & crawling.
I've only ever used 2S lipos in my rigs but tempted to try 3S with either a 1800 or 2200 mah pack.
I'm just wondering what sort of run time I can expect.
The Dark Knight is offline   Reply With Quote
Old 01-16-2018, 08:08 AM   #2
Default Re: Wraith Spawn run time
3s 2200 should get 1.5 hours or so depending on your throttle finger.
allanon1965 is offline   Reply With Quote
Old 01-16-2018, 08:31 AM   #3
Thanks, I'll pickup a couple then.
I've never ran 3S before so will be interesting to see the difference.
Old 01-16-2018, 08:55 AM   #4
50% faster than 2s.
Ninomaniac is offline   Reply With Quote
Old 01-21-2018, 11:29 AM   #5
I run a hobbywing 1080 and a 35t with 3s 5000mah 25c lipo and have gotten between 2 to 4 hrs just depends on how much full throttle you do but general crawling and trailing you get a long run time
bigplow is offline   Reply With Quote
Old 02-04-2018, 07:45 AM   #6
What brand Lipo is it? And where do you have it mounted? I'm trying to find one that will fit in the same sized area of a 5200 2S. I run mine in front of the firewall, under the hood.
Sent from my SM-J727V using Tapatalk
dieselmudder is offline   Reply With Quote
Wraith Spawn run time - Similar Threads
AXIAL WRAITH SPAWN - wet swamp run waqr Videos! 1 07-29-2017 06:11 AM
Wraith run #028 - Wraith Spawn with Little Joe JoeConti Videos! 0 02-01-2015 11:55 AM
Imthatguy's Axial Wraith Spawn Winter Run imthatguy Scale Videos! 1 01-25-2015 07:49 PM
