03-04-2018, 10:49 AM | #1 |
Pebble Pounder Join Date: May 2010 Location: Minnesota
| Spur gear recommendation.
How big of a spur gear do you guys recommend on a Wraith? I'll be strictly crawling. With a 13t Crawlmaster motor on 3s?
03-04-2018, 11:04 AM | #2 |
Pebble Pounder Join Date: Mar 2015 Location: france
| Re: Spur gear recommendation.
I'd say 43/13. Envoyé de mon SM-G930F en utilisant Tapatalk |
03-04-2018, 12:25 PM | #3 |
I fit a 64 tooth Axial Yeti spur. I had to trim the cover a little bit for it to clear the driveshaft.
03-04-2018, 11:12 PM | #4 |
Rock Crawler Join Date: Mar 2016 Location: Zagreb, Croatia
| Re: Spur gear recommendation. Too high for crawling. The stock Spawn kit spur (32P) is 56t, I have a 9T pinion and frankly I'd go even lower for strict crawling with the 35T cheapo motor I use. Not sure how that compares to the Crawlmaster but maybe fitting that bigger spur Brake Weight mentions would get you closer to the sweet spot. |
03-05-2018, 09:51 AM | #5 |
Quarry Creeper Join Date: Aug 2017 Location: Surface of the Sun
Brake Weight already helped me with this SAME situation! His recommendation is a really good one, as long as you're running a low-mid kv Brushless and/or a 3S Lipo.... That's the thing, different setups, different tuning. I'm running OLD School NiMh Batteries!! and a HH TorqueMaster Pro Handwound 35 Turn Motor. I found (with help) that 60/10 put my right where I needed to be! Good, Slow Speed control, lots of Torque. Fast enough for this old Fart to walk with it!! If I want more Speed, I'd STILL go with NiMh! 8 or 9 Cell.... ..... Those are two examples of near each end of the Power Spectrum. Not to be confusing, but Tire Size comes into play also. If you're rolling on 5-1/2" Tires or larger, maybe 64 Tooth Spur would be better for Crawling. Have fun!! |
Spur gear recommendation. - Similar Threads | ||||
Gear Recommendation For U4RC Racing | OurJK | Axial RR10 Bomber | 2 | 02-29-2016 05:30 PM |
Is there a metal upgrade gear for the 80T spur gear? | maddogs1965 | Axial Wraith | 9 | 03-25-2014 11:31 AM |
Which pinion gear works best with RC4WD Steel spur gear? | e32lover | HPI Wheely King | 8 | 03-10-2013 06:09 PM |
Which spur gear and pinion gear with 35t motor | vegas1973 | General Crawlers | 1 | 08-19-2012 11:42 AM |
Wobbling spur gear....Need alum. gear hub! | sickfab | HPI Wheely King | 26 | 10-01-2007 02:09 AM |
