Thread: VP lower link clocked correct?
Old 03-13-2018, 12:31 PM   #1
Default VP lower link clocked correct?
I've seen a few pictures of the Vanquish lower links clocked to provide high clearance, and I've also seen them clocked for rod end mount clearance. If that makes since.
What is the proper clocking of links.
Thanks
slickrock209 is offline   Reply With Quote
Old 03-16-2018, 01:37 AM   #2
Default Re: VP lower link clocked correct?
On these there is no proper, only thing thats important is what works for you.
I think you actually get better clearance with the links rolled "flat" to align the ends with the mounts better. The link is a straight line from skid to axle rather than the extra clearance at the skid but low at the axle end.
At least thats how I had them on mine.
altd896 is offline   Reply With Quote
VP lower link clocked correct? - Similar Threads
Scx10 II rear top link not correct size. Cortina79 Axial SCX10 II 4 07-11-2016 04:11 PM
finding the correct suspension link length rckjeep General Crawlers 32 10-26-2011 08:03 PM
Correct upper link length for stock setup? Jus Axial AX-10 Scorpion 5 06-11-2008 01:13 AM
