06-30-2018, 08:19 PM | #1 |
RCC Addict Join Date: Nov 2016 Location: 1972 born Christian, Chinese.
| HR Extend Locked Differential Hub Spool 10mm or 20mm?
Wanna to try out these Hot Racing extended spool on my Wraith, but not sure what length should I buy! This HR Extended spool will be sitting on my Wraith’s stock skid plate with my newly received Vanquish SCX10 transmission case. SCP125T10 Extend Locked Differential Hub Spool 10mm SCP125T20 Extend Locked Differential Hub Spool 20mm Thanks guys for helping out here. Sent from my iPad using Tapatalk |
06-30-2018, 08:23 PM | #2 |
| Re: HR Extend Locked Differential Hub Spool 10mm or 20mm?
Forgot to let you guys know. My Wraith was on MIP Axial C1 X-Duty CVD Kit. https://www.amainhobbies.com/mip-axi...p15210/p481815 Sent from my iPad using Tapatalk |
07-01-2018, 04:25 PM | #3 |
Quarry Creeper Join Date: Feb 2015 Location: Norway
Upper one looks about right, only need to lenghten it one side.
07-01-2018, 04:58 PM | #4 |
| Re: HR Extend Locked Differential Hub Spool 10mm or 20mm? |
07-01-2018, 05:40 PM | #5 |
Not sure if itw what you need do, but Supershafty makes what you need. https://supershafty.com/collections/...of-5mm-outputs |
07-01-2018, 05:43 PM | #6 | |
| Re: HR Extend Locked Differential Hub Spool 10mm or 20mm? Quote:
Thanks good find. I was a supershafty customer. But their 5mm output is overkill. I still prefer 4mm. Currently I have incision and holding up well. Sent from my iPad using Tapatalk | |
07-02-2018, 03:56 AM | #7 |
5mm output is standard 6mm output is the "beefy" one.
HR Extend Locked Differential Hub Spool 10mm or 20mm? - Similar Threads | ||||
Any one ever use Hot Racing SCP125T20 Extend Locked Differential Hub Spool 20mm? | johnnyluv | Axial AX10 2nd-gen | 4 | 01-11-2018 02:15 PM |
Locked up FI spool and OT shafts | Motorider | Axial SCX10 II | 3 | 09-29-2017 01:52 AM |
Locked Up RC - FI Spool | Locked Up | Locked Up RC | 121 | 04-26-2017 10:20 AM |
Locked Up RC - FI Spool | Locked Up | General Crawlers | 3 | 07-05-2013 08:00 PM |
Extend your Worm and Spool life. | zagscrawler | Team Losi Comp Crawler | 11 | 06-27-2010 10:23 AM |
