04-07-2019, 04:36 PM | #1 |
Newbie Join Date: Mar 2019 Location: Mesa
| I have a problem
I was playing at this rock course and i did something to the rear gearbox or axle or something. when its in a bind the rear end stutters and slips the front end does fine
04-07-2019, 05:33 PM | #2 |
| Re: I have a problem
I am looking for gearbox gears. I really dont know what im looking for
04-07-2019, 06:11 PM | #3 |
| Re: I have a problem |
04-07-2019, 07:16 PM | #4 |
check the bearings first then for missing teeth on the gears the inner pinnion bearing and the ring gear side bearings like to explode to much side load on the bearings the pinnion bearing pocket can be modified to fit a bigger bearing or you can order one already opend up for the bigger pinnion bearing the other bearing you just need to keep a eye on and keep one or 2 on hand for spares also on hot days with alot of power the axle housing itself can flex and cause the gears to slip and can grind the teeth down to nothing but you would have to be puting alot of power though it for that to happen |
04-08-2019, 07:24 AM | #5 |
Quarry Creeper Join Date: Feb 2018 Location: East otis
Did you check for a crack in your drive shaft? I'm assuming you have the stock plastic ones. If it's a loud click when it slips it could be one of the female ends cracked and is spinning around the inner male end of the driveshaft. I've cracked mine a couple times. Sent from my SAMSUNG-SM-G920A using Tapatalk |
04-08-2019, 07:45 PM | #6 |
I immediately thought it was the gearbox I have not had a chance to tear it apart. it is a 2.2 and it has steel drive shafts. It was a kit.
04-13-2019, 06:55 PM | #7 |
The sound was coming from the rear differential. I tore down the rear dif and i can not see anything wrong the ring gear and the pinion gear all look fine
04-13-2019, 07:16 PM | #8 |
Quarry Creeper Join Date: Oct 2011 Location: Shirley
Did you spin the hex inside the wheel? Or the pin in the hex adapter? If its plastic lockes then it could have spun the axle shaft inside those as well. Sent from my SM-J727V using Tapatalk |
04-14-2019, 07:59 AM | #9 |
04-14-2019, 08:13 AM | #10 |
Open the locker too. The stock axial locker has a square cheapo metal locker the axles go into. They split or round out and the axles will spin in a bind. Sent from my SAMSUNG-SM-G920A using Tapatalk |
04-14-2019, 09:03 PM | #11 |
I checked the hexes and the wheels and the pins can not find anything wrong. how can i check the locker pull the ring gear apart? |
04-14-2019, 09:12 PM | #12 |
RCC Addict Join Date: Jan 2007 Location: Arkansas
| Re: I have a problem Remove the screws that hold the ring gear to the plastic housing. Usually, one of the tabs on the lockers breaks off and will allow the locker to spin within the housing. You can buy an aftermarket spool from Locked Up RC, Incision, or a few other brands that will be much more durable than the plastic housing/pot metal stock setup.
04-14-2019, 09:53 PM | #13 |
| Re: I have a problem This usaly only happens to one wheel at a time but could happen to both if you don't find a blown bearing look at the locker there worth replacing anyway the cheap lockers are just as good as the expensive ones
04-25-2019, 05:51 AM | #14 |
Newbie Join Date: Sep 2008 Location: M
to much pinion/ ring gear backlash. feels ok ish by hand but toss in a plastic housing and things deflect even more.
I have a problem - Similar Threads | ||||
Problem with Tekin RS system in my LCC, will a BEC fix my problem? | rcboy514 | Electronics | 3 | 01-12-2012 05:55 PM |
Tekin Problem or Radio Problem? | Harvo | Electronics | 8 | 07-30-2010 06:02 AM |
Little bit of a problem, Possibly big problem... | C_Money | Electronics | 11 | 03-08-2010 05:49 PM |
Charger problem or power problem? | Rockfrog | Electronics | 4 | 10-09-2009 01:10 PM |
* Problem * Clicking Problem on my 1/18th | clodman | General Crawlers | 6 | 04-08-2006 08:40 AM |
